is it legal to switch from Halogen bulb to LED in california ? (high beam) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 09-07-2010, 05:41 PM   #1 (permalink)
View qinboxmail's Photo Gallery
Question is it legal to switch from Halogen bulb to LED in california ? (high beam)
Thanks
qinboxmail is offline   Reply With Quote
Old 09-07-2010, 05:46 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
Here's a great place to check, the California DMV's web site for vehicular codes.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 09-08-2010, 02:29 AM   #3 (permalink)
View messerchmidt's Photo Gallery
buy a used set off hids off ebay, and wire them in using a relay. its what i did
the self leveling and washer req are not required per-say
messerchmidt is offline   Reply With Quote
The Following User Says Thank You to messerchmidt For This Useful Post:
qinboxmail (09-08-2010)
Old 09-08-2010, 11:40 AM   #4 (permalink)
I was wondering if it's legal to use LED bulbs instead of Halogen bulbs.
Old 09-08-2010, 12:37 PM   #5 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
Be aware of using anything but a halogen in the high beam slot. The day time running lamps use the high beams, and they are on all the time at reduced voltage. This will most likely fry any LED bulbs. Unless you set to DRL off on the stalk, and turn your lights on manually. You lose the auto functionality by doing that.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 09-08-2010, 01:07 PM   #6 (permalink)
How do I know how many Watt the bulb my car needed ?
Would this http://cgi.ebay.com/ebaymotors/2-X-H...Q5fAccessories work ?
Thanks
Old 09-08-2010, 07:00 PM   #7 (permalink)
It Wasn't Me
Factory brights are 65 watts usually. Anything higher can and will melt some harnesses. I've personally seen the damage a 100 watt bulb did to 65 watt harness. Melted connecters and insulation. Could have caused a fire.
Old 09-09-2010, 06:53 PM   #8 (permalink)
the reason i say to get the hid housings off ebay is because they will aim the beam correctly.
if you use your stock one, you will blind everyone and that is not legal (although not enforced)
if you change the bulbs to higher output halogens, use Sylvania bulbs. the no-name chinese ones will cause damage.
