There is a drain plug for the radiator and a drain **** for the engine block that's located down below on the front of the motor. Hard to see the engine drain **** from above.
There are plastic shrouds underneath that need to be removed in order to obtain a view of where the engine drain **** is - again - down in the lower front of motor.
If you drain from the engine drain **** you will drain the engine block and radiator.
I always remove the radiator drain plug as well anyway to catch the remaining dribble in the radiator.
If you like to flush with a garden hose - remove thermostat; then reconnect t-stat housing.
There remains the issue of flushing the heater core and that's done by removing heater hoses usually at rear of motor. I haven't explored this on a 2GR-FE and will most likely just do what I've mentioned above.
Wifes car has about 95K on the odometer - won't be long B4 I'm doing this.
