How to replace front wheel bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 10-21-2010, 03:56 PM   #1 (permalink)
View Netjive8's Photo Gallery
I've been having a lot of noise coming from the front left tire, and I finally had it diagnosed as a bad wheel bearing today.
I noticed that the front wheel bearings are sold individually while the rear wheel bearings are sold as hub assemblies. Is there a certain way that the front wheel bearings have to be removed and pressed on? I'm trying to see if this is a DIY repair.
Any tips would be greatly appreciated.
Netjive8 is offline   Reply With Quote
Old 10-26-2010, 09:02 PM   #2 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
Downloads for you here:
http://members.cox.net/n0v8or/30-19.pdf
http://members.cox.net/n0v8or/30-20.pdf
"SST" means Special Service Tool (not usually commercially available).
This does not look like a DIY job unless you have access to an arbor press.
inov8 is offline   Reply With Quote
Old 10-26-2010, 09:33 PM   #3 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
Pressing bearings in & out is a service provided by machine shops for a reasonable fee. If you have one within a reasonable distance, it can make the job DIY without your having a press.
TedL is offline   Reply With Quote
Old 10-26-2010, 10:06 PM   #4 (permalink)
Thanks for the downloads.
I will plan on taking the hub assembly to a machine shop to have the old bearing pressed out and the new bearing pressed in.
Old 10-30-2010, 12:53 PM   #5 (permalink)
View HiltonII's Photo Gallery
There is a TSB on vibration which is caused by the front wheel bearings and spindle. I just had mine replaced on my 07. I had vibration in the steering wheel and seat. It was all done under warranty.
HiltonII is offline   Reply With Quote
Old 11-01-2010, 02:31 PM   #6 (permalink)
View Kellc1's Photo Gallery
TSB Wheel bearing/spindle
Hello - You don't happen to know the TSB number for that do you? My front end seems noisier than it should be. Thanks~
Kelly
Kellc1 is offline   Reply With Quote
Old 11-01-2010, 05:29 PM   #7 (permalink)
SUSPENSION:FRONT
  • TSB #TSB-0106-08
    NHTSA ID #10025856
    • Date Announced: JUNE 11 2008
    • Additional Info: How to Fix
    Summary: TOYOTA: FRONT SUSPENSION- SOME 2007-2008 MODEL YEAR AVALON, CAMRY, CAMRY HV, AND SOLARA VEHICLES MAY EXHIBIT A STEERING WHEEL FLUTTER AND/OR A BODY VIBRATION (FLOOR OR SEATS) AT HIGHWAY SPEEDS (APPROX. 65-75 MPH [105-121 KM/H]). *PE
