Tire Pressure 06 Limited - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 11-21-2010, 02:05 PM   #1 (permalink)
View adguy's Photo Gallery
I have a 2006 Limited I just bought used. I think the tire is a different size than on the XLS, but I cannot find this info.
Inside the door it says Tire PSI is 32.
On the Michelin Tires it says 44 PSI.
44 seems high, but I don't know.
Does someone know what the correct tire pressure is in the Limited tires?
Thanks so much.
adguy is offline   Reply With Quote
Old 11-21-2010, 03:04 PM   #2 (permalink)
I split the difference and put 41 psi.
Is this the right move?
Old 11-21-2010, 03:34 PM   #3 (permalink)
Tech1984's Avatar
Gameroom cash: $255850
View Tech1984's Photo Gallery
We do 35 all and 40 in the spare.
Tech1984 is online now   Reply With Quote
Old 11-21-2010, 05:21 PM   #4 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
The sidewall is max pressure for the tire, it has nothing to do with what you should be running the car at. The door panel is the correct spec. Adjust to personal preference if 32psi is too soft for you. The number on the side of the tire is a not to exceed number.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 11-21-2010, 06:35 PM   #5 (permalink)
Thanks.
I'll have to bleed some air out.
I wondered why the door panel was different from the tire.
Thanks again
Old 11-21-2010, 08:37 PM   #6 (permalink)
View GoFaSSter's Photo Gallery
This is spot on and something that a lot of people do not know. You have to keep an eye on the guys at the oil change places as well, because they are not all properly trained.
GoFaSSter is offline   Reply With Quote
Old 11-21-2010, 09:32 PM   #7 (permalink)
Does too much air effect gas mileage?
Does more air keep the tires from wearing out?
Thanks.
Old 11-21-2010, 09:45 PM   #8 (permalink)
To much air and the tire can bow up in the middle and cause premature wear in the center, too little and you can wear the outer edges too fast. Generally higher pressure can yield better mpg but a very small change compared to proper inflation levels. This all depends on the load you are carrying as well. Trucks tend to need different inflation pressures based on the large loads or trailers they are hauling.
Old 11-22-2010, 08:20 AM   #9 (permalink)
Thanks, I'll bleed it out to 35.
Old 11-22-2010, 12:16 PM   #10 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3635050
+1
I keep my Gen 2 Avalon's tires at 34 PSI with no wear issues at all.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 11-26-2010, 06:27 PM   #11 (permalink)
View Mike Murrell's Photo Gallery
Door panel pressures are way too soft for me.
Mike Murrell is offline   Reply With Quote
Old 11-27-2010, 12:59 AM   #12 (permalink)
View messerchmidt's Photo Gallery
44 is the max before it goes boom! do not set it to 44!
32 is a tad bit low. I myself use 35 psi (test it when the car have not been in use for awhile as the tires heat up when in use)
messerchmidt is offline   Reply With Quote
Old 11-27-2010, 09:29 AM   #13 (permalink)
It Wasn't Me
I just put my new tires at 32, the rears look ok, but the fronts look under inflated. I will probably up it to 34 when I get back to IL.
Old 11-27-2010, 03:22 PM   #14 (permalink)
View tashidad's Photo Gallery
I have a 2006 Avalon XL and the tires I have on it now are kept at 35 and wear has been great!!. MPG on long trips in the low 30s. I use synthetic oil--Mobil 1 and have for a long time.
tashidad is offline   Reply With Quote
Old 11-27-2010, 03:31 PM   #15 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Here at the dealer we set all the pressures to 35 PSI
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
