06 avalon, starting in the morning - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 11-28-2010, 01:29 PM   #1 (permalink)
View bradda-b's Photo Gallery
I have an 06 avalon touring and just recently we noticed that the car doesn't start on the first crank [in the morning] like before. It will start after the second or third try. Does anyone have this same thing happening? Am I doing something wrong? I am doing what the manual says and not depress the accelerator and just start the car. Is there anything I can do to make the car start on the first try like before? thanks
bradda-b is offline   Reply With Quote
Old 11-28-2010, 02:18 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3635050
First thing I'd suspect is the battery. Considering that you've had your Avalon 4 years now and that most batteries start giving out at 5 years, it may be your battery is telling you it's time for a change. You could have it tested, but in my opinion I'd go ahead and change it since you experience hot conditions in Hawaii that will prematurely age a battery.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 12-05-2010, 11:53 PM   #3 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
1. Battery - have it tested before you just go & replace it.
2. Idle Air Controller gunked-up. Where does car idle once you get it started?
If it doesn't idle high -- over 1200-1500 rpm for a few minutes, if you let it run (in neutral), then suspect the IAC. Eventually what happens is that the car will start then die immediately.
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Riick is offline   Reply With Quote
