Center vent air conditioning problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 12-02-2010, 12:46 PM   #1 (permalink)
View ttjr's Photo Gallery
Question Center vent air conditioning problem
I am having a problem with the center dash vents. The vents shut off when the fan setting is increased to a high setting and the AC mode is set for the dash. I can hear a flapper door closing but then it will reopen when the fan is turned off. Is there an easy fix for this? I would have to guess that there is an actuator arm that came off???
05 Avalon XLS
ttjr is offline   Reply With Quote
Old 12-02-2010, 02:30 PM   #2 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
Are you using 'Auto' mode? What does the Air Conditioner display show (where the air is being directed) when that happens?
Tom in Tacoma is offline   Reply With Quote
Old 12-02-2010, 02:38 PM   #3 (permalink)
I can either use auto mode or manual mode. As soon as the airflow through the center vents approaches max fan I hear a thunk, the vents go dead and I hear the fan noise increase. I turn off the fan, I again hear a thunk and can then turn on the fan again with air coming out of the center vents until near max fan the process repeats itself. The LCD shows the air blowing through the vents.
Old 12-02-2010, 02:58 PM   #4 (permalink)
'07 Avalon Limited
That doesn't sound right... Sounds like you might need to eyeball it.
