replacing accessory belt 05 lim - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 12-17-2010, 04:12 AM   #1 (permalink)
View 740ilsamuel's Photo Gallery
is it hard to replace the accessory belt on the 05 limited?
740ilsamuel is offline   Reply With Quote
Old 12-23-2010, 09:40 AM   #2 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
I'll tell you when I finish doing mine.
Looks like a standard serpentine belt, and spring loaded tensioner.
Belt itself runs anywhere from $13 - $30; I'll probably use a Gates, I used to work for them.
All I should have to do is
(a) Make an accurate diagram of the way the belt goes round the various pulleys, and
(b) Find where wrench (or socket wrench) fits onto tensioner, & correct direction to release tension.
Now, I usually fit an extension bar to wrench (usually a 24"-36" length of 3/4" iron pipe),
so it's EZ to release tension and EZ to hold it released.
Next, pop belt off, correctly run new belt around pulleys.
Release belt tensioner, remove wrench
Check work to be sure belt 100% in proper grooves.
Start car and check everything OK (again)
Done.
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Riick is offline   Reply With Quote
Old 12-31-2010, 01:20 AM   #3 (permalink)
View messerchmidt's Photo Gallery
Canada
i ordered everything from toyotapartsdirect
belt,water pump, spark plugs, etc
cost me 200$ to have me mechanic do everything.
i would do the water pump with the belt because they tend to go at the same time and half the work is the same
messerchmidt is offline   Reply With Quote
Old 12-31-2010, 02:15 PM   #4 (permalink)
Done.
Old 12-31-2010, 02:17 PM   #5 (permalink)
thanks riick
