05 Limited won't start, battery seems ok but no sound when pressing start/stop - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 12-27-2010, 09:57 PM   #1 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
over the weekend, we picked up a 05 Limited. At the dealer, we were not able to start the car by pressing the start/stop. We need to keep it close to the button. Confirmed dead battery on remote.
After I got the car home, I rolled down all the windows and have the trunk opened for a couple days. This morning, I opened the door (had it opened for maybe 5-10 minutes) all the sudden no light. Double checked, the battery seems dead (~3.5V). Few hours later on a charger, it showed ~12.4V but when I tried to start, I heard the usual steering column release sound, but that's it. No sound from the motor at all. Turned on all the light, headlight, seems ok but still no sound from the motor.
I searched the net, someone mentioned the brake switch but not sure if that's the case. Any idea?
grandpapa is offline   Reply With Quote
Old 12-28-2010, 08:58 AM   #2 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
Trunk lid open for 2 days suggests the trunk light was on for 2 days as well, which may explain the dead battery. Unless you have a high current charger (>10amps), it will probably require more than a few hours to restore enough charge to operate the starter.
Also check to be sure the reverse (back-up) lights are working. The starter interlock is powered from the reverse lamps circuit. I had a bulb fail and blow the fuse for the back-up lamps. The push button would not operate the starter until the fuse was replaced.
inov8 is offline   Reply With Quote
Old 12-28-2010, 04:59 PM   #3 (permalink)
thanks for the info, and yes you are right. The charger I have is an old style, 2amp. 12 hours later, I was able to start the car.
While waiting for the recharge, I notice the jump start method didn't work (at least for me). It was hard to locate a (-) point on the car and I just pick the little metal bracket in front of the battery but was unable to jump start (even though all the light got turn on ok)
