AT Filter Kit - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 01-15-2011, 10:31 AM   #1 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
AT Filter Kit
http://www.oreillyauto.com/site/c/de...3230&ppt=C0023
I am going to be changing the transmission fluid sometime soon on my dad's avalon. I read the following threads to understand what needs to be done.
http://www.bobistheoilguy.com/forums...&Number=922912
http://www.tundrasolutions.com/forum...-transmission/
Would it do no harm to remove the pan and replace the filter and gasket with the WIX 58010 filter kit?
Other than that the procedure looks pretty simple, I have done about 4 drain and refills on my 99 this year alone and haven't had any problems.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 01-16-2011, 02:58 PM   #2 (permalink)
Avy
Nobody?
I noticed the trans. pan gasket is leaking, while doing an oil change. Now it needs replacement anyways. So is it ok to use the Wix Filter kit?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-16-2011, 04:25 PM   #3 (permalink)
View Mike Murrell's Photo Gallery
I've used Wix Oil/Air/Transmission filters in Asian vehicles.
In my opinion - they are high quality.
Mike Murrell is offline   Reply With Quote
The Following User Says Thank You to Mike Murrell For This Useful Post:
pmesfun (01-16-2011)
Old 01-16-2011, 04:58 PM   #4 (permalink)
Avy
Great. I use them for everything else, but I was making sure if OEM was the way to go for this. Also, the windshield washer tank is leaking, hopefully its a loose of broken hose.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-16-2011, 08:41 PM   #5 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
There's a TSB (Technical Service Bulletin) about the washer fluid tank leak. Seems the hose pops off the bottom. The fix is to put the hose back on and secure it with a clamp. Toyota will take care of it if the car is under warranty.
Tom in Tacoma is offline   Reply With Quote
Old 01-16-2011, 09:01 PM   #6 (permalink)
Avy
Well its an 07 with 53k miles, idk if its under warranty. I'll take care of it myself since its such an easy fix.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-17-2011, 09:01 AM   #7 (permalink)
View Doobiewah's Photo Gallery
I, too, have used Wix AT filter kits (not in Avys, tho...). The gaskets were excellent and tightened down nicely.
Doobiewah is offline   Reply With Quote
The Following User Says Thank You to Doobiewah For This Useful Post:
pmesfun (01-17-2011)
