Tire pressure light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 01-22-2011, 01:10 PM   #1 (permalink)
View leeronald4's Photo Gallery
Tire pressure light
I just put 18x8 Konig wheels with 235/45/18 Continental DWS tires on my Avalon. I had the tire shop put my TPMS out of my old tires and now the tire pressure light stays on. Can someone tell me what I need to do to get the light to go off?
leeronald4 is offline   Reply With Quote
Old 01-22-2011, 02:01 PM   #2 (permalink)
View brad_i2001's Photo Gallery
Put your car in accessory mode and press and hold the button under your key slot for 30 sec. This resets the tire pressure lamp and should only light if the tires are under the psi that you deemed good. Be sure you check each tire first for proper inflation.
brad_i2001 is offline   Reply With Quote
Old 01-23-2011, 12:46 AM   #3 (permalink)
View saabdriver59's Photo Gallery
CHECK THE SPARE TIRE IN YOUR TRUNK!!!
I believe it's Toyota's spec to change with new tires (making it a 5 tire purchase which is a ridiculaous assumption) but if you need to make sure the pressure is the same as the others - all transmitters will be in range with each other and not complain to your cars monitoring system. And yes, there is a transmitter in the one back there.
saabdriver59 is offline   Reply With Quote
