With ignition switch in the “ON” position, do the following:
1. Push down and hold the driver’s door power window switch to completely open the window.
2. Pull and hold up the driver’s door power window switch until the window closes. Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the “one–touch open and close” function by fully pushing the switch briefly to the “DOWN” and “UP” positions.
At this time the power window switch for the passenger’s door window should be blinking.
4. Push down and hold the passenger’s door power window switch to completely open the window.
5. Pull and hold up the passenger’s door power window switch until the window closes. Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
6. Check for proper operation of the “one–touch open and close” function by fully pushing the switch briefly to the “DOWN” and “UP” positions.
 It worked fine until I fixed it!
