Can I replace HID with regular headlamps? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 02-03-2011, 08:54 PM   #1 (permalink)
View actionpaintball's Photo Gallery
I have a nice 2007 avalon that was in a light front end accident that took out both headlamps completely. I am rebuilding using factory parts and just want to get the headlamps together as cheaply as I can.
Anyone know if I can just bypass the HID ballasts and install regular lamps/bulbs? Will that mess with the lamp level controller? I have no problem installing the correct matching halogen relays; I just think that trying to rebuild the HID back to factory specs could get costly at this point
Any input appreciated.
actionpaintball is offline   Reply With Quote
Old 02-06-2011, 01:01 PM   #2 (permalink)
Bump...I am sure there some people who have done a conversion to upgrade to a factory HID-any input on going back to standard? Will I throw headlight level codes or run into major wiring headaches?
Old 02-06-2011, 02:14 PM   #3 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
Actually, I don't know of anyone that's done an upgrade to a factory HID setup. That would be cost prohibitive when you compare it to an aftermarket HID setup. That might be why you're not getting a response. Why not just find an aftermarket replacement HID and retain not only the designed-for-HID assembly, but also the self-leveling feature? You'll also save yourself the headache of trying to figure out how to 'de-feature' your car in the process.
Tom in Tacoma is offline   Reply With Quote
Old 02-06-2011, 03:21 PM   #4 (permalink)
View Axxis8203's Photo Gallery
ddmtuning.com is where i got my replacement HID's. it's much easier to do it that way than to retrofit/downgrade your vehicle to accept
halogens.
Bulbs themselves are $15/pair and a kit is $45
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 02-06-2011, 04:14 PM   #5 (permalink)
View AVA1's Photo Gallery
No you can not, the wiring for a oem xenon system is different than that of a regular filament bulb. remember that a regular bulb is plugged into the wiring harness, in a xenon setup the wiring harness is plugged into the ballast then the ballast is plug to the xenon bulb.
AVA1 is offline   Reply With Quote
