2008 Avalon - Lower MPG than expected - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 02-12-2011, 02:48 PM   #1 (permalink)
View volantis's Photo Gallery
I bought a 2008 Limited in December. I've recently been getting lower gas mileage than I expect based on others' comments. Any feedback on what could be causing it? Yesterday I drove from TN to MO. I started w/ 3/4 tank and got 23.5 MPG cruising around 75 MPH w/ laser cruise control. The next tank got 27.9 according to the display, which usually reads 1.5 MPG high, while cruising around 73 MPH.
Is this normal or should I be getting better? I've thought it could be tires, tire pressure, gas, or maybe oil (haven't gotten to my first change yet, but it is CPO so I assume it has the correct synthetic in it).
Any thoughts on what I can do to get better mileage, assuming that's not normal?
volantis is offline   Reply With Quote
Old 02-12-2011, 03:01 PM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
1) If you drive 70 instead of 75 mph, you will see in increase in mileage
2) Double check tire pressure. Don't assume it was set correctly at the dealership.
3) 2008 Avalon did not come with synthetic oil originally, it's 5w-30 dino oil. You can, however, switch to synthetic if you like.
4) It's winter. I know you're from TN, but it's still colder there than most cars would like. You will always see a drop in mileage when it's colder outside. My 4 cyl. Camry went from a 28 mpg average in summer to 21 mpg in winter. (Granted, it's colder here, I know.)
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 02-12-2011, 03:10 PM   #3 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
I get over 30 in summer with summer gas. I routinely get 23-26 in winter. EPA recently approved E15 gas for 2008 and newer cars too, which has more ethanol, if that's in your area, that would cause worse mileage as well.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 02-12-2011, 09:50 PM   #4 (permalink)
Nothings better!
TheUltimateBohab's Avatar
View TheUltimateBohab's Photo Gallery
winter makes a difference but a huge difference (I’ve noticed it in every car I’ve ever driven) is where you get gas ill get gas at a shell or Mobil and get around 30-35 depending on the temp above or below freezing makes the difference, but if I get gas at the Phillips 66 or the BP in my town I’ll get 22 at best regardless of the temp. I use premium btw
TheUltimateBohab is offline   Reply With Quote
Old 02-13-2011, 08:31 AM   #5 (permalink)
Love the Open Road!
tfelton's Avatar
Gameroom cash: $208620
View tfelton's Photo Gallery
I hadn't focused on temperature as being a factor, however, I checked my mpg records and found about a 4 mpg difference from winter to summer (28 vs 24). On long trips in the Summer I will get in the low 30s. This has been true for the years I've had the car which I bought in February of 2008. The car now has 59,000+ miles on it. As far as maintenance goes I use 35 lbs in the tires and Mobil 1 0W-30 oil. I understand 15% corn in the gas has been approved but I haven't seen it yet at the pump. I hope it takes a long time coming.
2012 Corolla S
2006 Tundra
tfelton is offline   Reply With Quote
Old 02-13-2011, 10:34 PM   #6 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Try some fuel injector cleaner.
On the 07, it averages around 22-23 during winter and about 25-27 in the summer. City driving. On trips with my dad driving its gets around 31-33.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 02-13-2011, 11:51 PM   #7 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3635050
Speed is certainly your biggest mileage killer. My 2002 XL gets 32 MPG at 65 MPH, and at 70 MPH drops to 29 MPG. You have to decide which is more important, mileage or speed.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 02-14-2011, 05:30 PM   #8 (permalink)
This was my first thought, but I routinely see people claiming 75-80 MPH with over 30 MPG. I'll check the air in the tires and maybe try some new gas.
I saw someone else using premium. Just curious why. The car doesn't call for it and I doubt the compression ratio is very high, so it seems like it would hurt mileage or stay the same, but not help.
Old 02-14-2011, 09:16 PM   #9 (permalink)
Love the Open Road!
tfelton's Avatar
Another factor I feel greatly influences mpg is wind. We drive out west a lot and when you're on I-40, I-70, or I-80 for a whole day (especially I-80 in Wyoming) wind makes a big difference. I also feel that if you're driving a long distance in a day (we normally do 1,000+ miles the first day of a long trip) not driving at break-neck speed makes for a more enjoyable and relaxed drive.
I tried premium and found no mpg advantage at all.
2012 Corolla S
2006 Tundra
Old 02-14-2011, 10:04 PM   #10 (permalink)
View Mike Murrell's Photo Gallery
Ignore the MPG display on the dash....it is all over the place.
My wifes '06 Avalon has never gotten anywhere close to what was advertised on the window sticker.
My observation is cars get approx. 15% less mpg than what the mfg puts on the window sticker.
If you are getting what the mfg advertised.....good for you.
Mike Murrell is offline   Reply With Quote
Old 02-14-2011, 11:02 PM   #11 (permalink)
View eldernerd's Photo Gallery
Interesting to see other's experience which are very similar to what I've see in mileage figures. Wind...I'll get 3 to 4 MPG more driving east that west. Winter drops my mileage from 33-34 to 30-31 in an 08 Limited at speeds of 70 to 72 MPH. I run the tires at 34 pounds but may drop that to 32 if there's ice or snowpack anticipated in the area.
eldernerd is offline   Reply With Quote
Old 02-15-2011, 01:05 AM   #12 (permalink)
Do you feel lucky?
TrailDust's Avatar
I call on anyone claiming over 30 MPG at those speeds. Don't believe them.
2002 Avalon XL
Old 02-15-2011, 07:17 AM   #13 (permalink)
Love the Open Road!
tfelton's Avatar
i did a trip to Dallas not long ago: first tank was 366.8 miles using 11.924 gallons for 30.76 mpg; second tank was 292.0 miles using 9.695 gallons for 30.1 mpg. Mileage was interstate 30 plus driving in Dallas. These are actual numbers, not from the dash.
2012 Corolla S
2006 Tundra
Old 02-15-2011, 11:57 AM   #14 (permalink)
Do you feel lucky?
TrailDust's Avatar
What was your average speed?
2002 Avalon XL
Old 02-15-2011, 02:33 PM   #15 (permalink)
Love the Open Road!
tfelton's Avatar
I-30 is 70 mph so I do 70 to 75.
2012 Corolla S
2006 Tundra
