2005 Avalon ..Need Help please!!
vehicle has 115,00 on it. recently ive started throwing codes that lead to a bad coil. ive replaced 2 out of 6 so far. light came on today and i went to get it tested since it is missing again. im getting the p00015 code which i believe was the camshaft position sensor and i also had two other codes for coils D and F. my question is this. which is bad? the camshaft sensor or the coils? if the sensor is bad, will it cause the coils to misfire, giving me the misfire D & F alarm? i plan on replacing all the coils eventually but at 100.00 a pop i thought i would do it as they start failing. i called autozone and they said that its saying i have 4 camshaft positioning sensors. dont really know where to start..thanks!
