DIY Audio - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 03-07-2011, 09:49 PM   #1 (permalink)
Ridin Slow...
Minus (-)'s Avatar
Gameroom cash: $201800
View Minus (-)'s Photo Gallery
DIY Audio
2006 XLS w/ navi and jbl synthesis.....what im tryna do is hook up a sub and amp while keeping my factory HU and amp....my problem is i need a diagram for the factory amp under the passenger seat,i need to know where the remote is and which wires to tap into....i've read that i need a Line Output Converter....If true i still need to know which wires to tap into...all thoughts are appreciated....
Minus (-) is online now   Reply With Quote
Old 03-08-2011, 12:18 PM   #2 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
It all depends on how much money you want to spend. Most amplifiers will have a Speaker Level (tapped right off of the oem speakers) input, in which case you don't need a Line out converter (LOC) Some amplifiers on the other hand, do not. There are also specialty LOCs that restore (or attempt to) any oem signal processing. But because you have a factory subwoofer that may not be necessary. (plus those LOCs are like $200-500, ouch!)
Something like this does the whole deal in one package:
http://www.crutchfield.com/s_108BASS...nk.html?tp=114
But I dare say if you already the JBL system in the avalon its probably not much better adding something like that Infininty BassLink, I have a Tahoe with similar oem equipped Bose system and that hits pretty hard.
Otherwise you will need a few components which I made a drawing representing hookup
Line out converter, you can just tie the two speaker level inputs together in parallel so it can handle 160WRMS
http://www.crutchfield.com/p_142LOC8...tml?search=loc
Then you need to have an amplifier hooked up, Id imagine it would be in the range of 500-1000W if you want to overcome the factory system by a noticeable amount. This will require 4 gauge wiring to the battery and a 100A fuse.
EQs and crossovers are not nessicary, because the signal will already be crossovered for the factory subwoofer
Once its all hooked up I would recommend detaching the factory sub woofer. (or leave it attached, its all preference)
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
The Following User Says Thank You to Jigg007 For This Useful Post:
Minus (-) (03-09-2011)
Old 03-08-2011, 11:24 PM   #3 (permalink)
Ridin Slow...
Minus (-)'s Avatar
WOW! WOW! WOW!.....U My Friend Are A Genius...Gonna Have One Of My Dudes Look At This And See If He Can Get It Started..I'm Gon Show U My Exact Euipment,b4 i order that loc80....if u got time lemme know if this is gonna work(I Bought It Already...Its Sittin On The Floor Waiting To Be Installed)....
Subwoofer:Kenwood Kfc3012 (1)
  • 12-inch, 4-ohm subwoofer with 1200 watts maximum power handling (400 watts rated)
  • Polypropylene cone with diamond array pattern and urethane surround
  • Improved cosmetic design, shallower mounting depth and longer cone excursion
  • 8AWG wire-capable push terminals for quick system setup
  • 86dB sensitivity, 39Hz - 300Hz frequency response
Amp:Crunch GPV1000.1
  • 2 x 250 W at 4 Ohms, 2 x 500 W at 2 Ohms, 1 x 1000 W at 4 Ohms Maxx Power
  • Twin-Coil Isolation Design with Fully Adjustable Crossovers that Include 24 dB Low-Pass and 24 dB Subsonic Filter;
  • RCA Line Outputs Include Amplifier Daisy-Chaining and 4 to 0 Gauge Power Connectors
  • Twin-Turbo MOSFET Exponential Variable-Power Supply High-Current Power Supplies and High-Speed MOSFET Outputs
  • 30th Anniversary Edition with Blue Halo Illuminated Crunch Logo and Selector Switch for Choice of Fixed Illumination
Old 03-10-2011, 01:20 PM   #4 (permalink)
Avarollin?
Jigg007's Avatar
Yeah, that amplifier I drew represented the new aftermarket Crunch you have now.
With that 4 ohm subwoofer you will likely bridge that amplifier into a single channel at 4 ohms. Use 12-14 gauge speaker wiring from the amplifier to the subwoofer.
With the addition of your LOC80 you have all the components, all you need after that is the wire(fuse too) and the know-how (or your friend) to install it.
Make sure you tap the LOC80 into the Avalon's subwoofer speaker wires. (if you just attach to a door speaker you'd be shooting yourself in the foot) After its all hooked up, I'd run it with no crossover set on the amplifier and see how it sounds
Old 03-10-2011, 02:43 PM   #5 (permalink)
Ridin Slow...
Minus (-)'s Avatar
iight....im bout to hit the stores up now and get what i need(loc80,sub box,4 gauge kicker amp kit,and 12-14g speaker wire)...think all that should run bout $150....appreciate ur input and that damn diagram...its raining now...prolly get it crackin tmrw w/ pics n vid
