2006 Avalon High Beam adjustment HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 03-10-2011, 10:48 PM   #1 (permalink)
View Lukessolara's Photo Gallery
I just bought a 2006 Avalon. I know how to adjust the low beam but the high beam is lower than the low beam and I know the low beam isn't to high it could even come up some more but I really need to get the high beam up more.
anybody got any ideas?
Thanks
L. Hall
Lukessolara is offline   Reply With Quote
Old 03-11-2011, 09:19 PM   #2 (permalink)
06 Avalon limited
View biker90's Photo Gallery
The high beams on my 06 limited suck!
I tried putting in better bulbs still sucks. Mine adjust by themselves but they just don't cut it.
biker90 is offline   Reply With Quote
Old 03-11-2011, 11:02 PM   #3 (permalink)
I don't have the HID lights in mine
Old 03-12-2011, 11:10 AM   #4 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
Is it even possible to adjust one without adjusting the other? They're both in the same housing.
Mine are the self-leveling HIDs so I don't know how much help I can be to ya...
2007 Avalon Limited - Love this car!
Tom in Tacoma is online now   Reply With Quote
Old 03-12-2011, 11:13 AM   #5 (permalink)
There is a way to adjust the low beam. but I still don't know about the high beam!
Old 03-29-2011, 09:59 PM   #6 (permalink)
Well I found out that the low beam adjustment should adjust the high beam also! Haha
Old 03-30-2011, 10:42 AM   #7 (permalink)
'07 Avalon Limited
...how 'bout that...
Old 07-31-2011, 12:48 PM   #8 (permalink)
View larry_b's Photo Gallery
upside down bulb
just got over that speed bump today on my 06 Avalon.
low and high beam are 2 separate bulbs.
both are adjusted together.
so if low beam is ok,
but the high beam is pointing to the ground about 10ft in front of the car ..
its because the high beam bulb is installed *upside* down!
rotate the bulb in its socket.
easy fix...
enjoy night driving again.
cu,
larry_b
larry_b is offline   Reply With Quote
Old 08-04-2011, 11:10 AM   #9 (permalink)
View tanner520's Photo Gallery
Man, I noticed my wife's Avalon has its low-beams pointing 10 feet in front of it and you can't see down the road at all. Where is the low-beam adjustment so we can see at night?
tanner520 is offline   Reply With Quote
Old 08-04-2011, 08:59 PM   #10 (permalink)
hey tanner,
if the problem started when a burned out bulb was replaced with a new one, then in all likelihood, the new bulb was installed upside down.
don't mess with the alignment.. have the mechanic flip the bulb in its socket.
i'm getting the feeling that Toyota has Avalon headlight bulbs that have an up-down direction... but they didn't put out a service notice. the new bulbs aren't labeled ... or... the mechanics don't read the package.
this seems to be a wide spread problem... that really shouldn't be an issue.
the owners manual recommends that headlights be changed by a mechanic because there can be high voltage around it...that could be life threatening.. so take care and let a pro fix it.
it is *amazing* what rotating the bulb 180 degrees does for beam alignment.
Tags
adjustment, high beams
