NGK DILFR6D11 or Denso FK20HR11 Spark Plugs ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 04-01-2011, 02:37 PM   #1 (permalink)
View Mike Murrell's Photo Gallery
Eyes popped out of my head when I first started searching for spark plugs for wifes '06 Avalon XL - 110K on the clock - 120K spark plug change time - will be here soon.
First site I found had the NGKs at $31.60 ea - $189.60 for all 6 !!!
Finally found a site where the Denso's are $10.79 ea; the NGKs $14.69 ea. and that beats ebay which I don't trust.
Anyone have any opinions about which is better?
My experience with these 2 brand of plugs on other Asian cars/motorcycles was 6 of one; half dozen of the other.
Thanks for your time.
Mike Murrell is offline   Reply With Quote
Old 04-01-2011, 10:07 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260740
View Yuko's Photo Gallery
NGK and Denso are pretty much equal to each other. Both are listed in the manual for my car and have use both with no ill effects. On some Toyota truck forums, owners find NGK spark plugs on one side of the engine and Denso on the other side from the factory. Have you check the parts store or dealership? Sometimes they're cheaeper there.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 04-02-2011, 02:08 AM   #3 (permalink)
Gameroom cash: $142500
View 00avxls's Photo Gallery
Had my spark plugs replaced not too long ago. Got 128k miles on my 06 avalon. I just took it to the dealership. I paid $185 total for parts and labor. I didn't think that was so bad.
00avxls is offline   Reply With Quote
Old 04-02-2011, 10:54 PM   #4 (permalink)
I agree on the equality statement made above. Ran both those brands in Asian hot rod bikes back in the 70s. Could never tell the difference then.
Went thru '06 FSM last night and saw the Denso part number mentioned.
Old 04-03-2011, 12:26 PM   #5 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
My car came with NGK's and I replaced them with Denso's because they were cheapest for me. $6 each from Toyota of Dallas vs. the $10 NGKs. I haven't felt any difference.
Toyotapartszone has Denso's the cheapest for the 05-up Avalon, $7.50 each.
http://www.toyotapartszone.com/oem/t...919-01247.html
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 05-27-2011, 10:26 AM   #6 (permalink)
CISA93's Avatar
View CISA93's Photo Gallery
If you haven't replaced your spark plugs yet. always use Permatex anti-seize on the threads. I was at my buddy's shop, mechanic pulled the spark plugs off a Lexus, one of them came out with the threads. The head technician went through the roof as did the manager. These are little tricks of the trade, but will save you alot of headaches later. Remember, they're aluminum engines and those spark plugs have been setting in there for years. Also, I use silicone spray or electro gel (Permatex) when reintalling the coil (small dad on the inside of the boot.
CISA93 is offline   Reply With Quote
Old 05-27-2011, 10:39 AM   #7 (permalink)
For sure - anti-seize on the theads and di-lectric grease(a dab) up in the boots/ign coil pack connectors.
Car is at 113,000 - first plug change in the not too distant future. Hope the factory used some lube on the plug threads when the engine was assembled.
Old 05-27-2011, 10:48 AM   #8 (permalink)
CISA93's Avatar
I have YET to see any factory do this. Just make sure your engine is cold, blow the hole out where spark plug is located (if you have a Vacula or air gun with a long tip BEFORE removing the coil (Any debris in that hole will fall into the combustion chamber upon removing the spark plug
Blow some air around the electrical connection to the coil because there is a small amount of abrasive dust that sometimes doesn't allow the connecter to come out.
We use a longer ratchet to get better leverage (if room allows) and then back out slowly. IF you can see down into the spark plug hole and it's gunky/dirty, shoot some brake cleaner (small amount) or throttle body cleaner, then a shot of air.
When reinstalling, always carefully check your gap, Have found some gaps to be out of range. Seems you've got a good handle on things and you've taken care of your car quite well. I also put some silicone spray on those electrical connectors they clip on well and will remove much better in future if needed. Good luck..
Old 05-27-2011, 10:54 AM   #9 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
Is it really necessary to have spark plugs replaced? I think I did it long long time ago on my very 1st OLD car. Since then, I have never done it on any car.
When you guys took out the old plugs, how does it compare to the new one? carbon buildup? oil? Or just like new?
grandpapa is offline   Reply With Quote
Old 05-27-2011, 11:14 AM   #10 (permalink)
CISA93's Avatar
Electrodes worn down, usually no carbon build up, unless there is a misfire, dirty fuel injectors, oil coming up through valve guide, ect. They just get old and worn, lose their "spark" due to the millions of firings they perform.
Old 05-27-2011, 11:29 AM   #11 (permalink)
Avy
I replaced the original ngk plugs at 130k on my 99. They looked very good for their age, electrodes weren't worn down and the gaps were in specs. I don't think they had antiseize, but came out with ease. I noticed no change in MPG, makes me consider running the new ones for another 150k.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-27-2011, 11:38 AM   #12 (permalink)
Some guys play golf; I work on cars. Both are expensive hobbies, but one is far more essential than the other.
As stated above, the electrode(usually the center one) wears and that widens that gap.
Replaced plugs on my '04 baseline Tacoma a few weeks ago. Gap is set at .032 - checked each plugs gap upon removal. Read approx. .050 in just about all 4 cases. Plugs had around 45,000 miles. Vehicle ran OK but idled maybe a hair smoother afterwards. Maybe the placebo affect was telling me that.
Old 05-27-2011, 12:04 PM   #13 (permalink)
CISA93's Avatar
I play on the side of safety and go with the anti-seize and the dielectric grease. I don't think's it a placebo because I've changed out too many spark plugs and then i've been told the throttle response was better, idling and gas mileage. So, for the price that you'll pay. It's much better to change your spark plugs and from my experience, NGK or Denso is the way to go. Never had luck with domestic brands because they don't have the durability (endure the stated mileage)
Old 05-31-2011, 11:09 AM   #14 (permalink)
I don't recall the regular maintenance call for spark plugs replacement. Wouldn't Toyota or the dealer already want to "steal" our money by asking us to do this?
Old 05-31-2011, 01:48 PM   #15 (permalink)
Avy
There isn't, they last for 120k.
99 Avalon XLS-149k
99 Lexus LS400-88k
