Need Help On Install - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 04-12-2011, 09:18 AM   #1 (permalink)
Ridin Slow...
Minus (-)'s Avatar
Gameroom cash: $201800
View Minus (-)'s Photo Gallery
I Have My 12" sub hooked with a 1,000 watt amp....everything is all wired up except for the remote wire....I'm trying figure out what to tap into...Or Any Other Suggestion??
Minus (-) is online now   Reply With Quote
Old 04-12-2011, 09:46 AM   #2 (permalink)
View Mike Murrell's Photo Gallery
Dont' know about the install - but I can't help but wonder how many batteries you're going to fry.
Mike Murrell is offline   Reply With Quote
Old 04-12-2011, 09:49 AM   #3 (permalink)
hghflyrjd1's Avatar
Gameroom cash: $179255
View hghflyrjd1's Photo Gallery
Fry batteries ?why?
Silver on Black Limited.Paid In Full.20s,HighLander 19s,Mesh Grill,Tint,8k Heads/Fogs,Kicker-12s,2 Headrest Tvs, WeatherTech Set. HI Haters!!...Check Me out On CarDomain...http://www.cardomain.com/ride/3821171
http://www.customsculture.com/magazine/read/my-1st-feature-jiggas-avalon-limited_25.html
hghflyrjd1 is offline   Reply With Quote
Old 04-12-2011, 10:35 AM   #4 (permalink)
Ridin Slow...
Minus (-)'s Avatar
Yea obviously he knows diddly squat....explain
Old 04-12-2011, 10:38 AM   #5 (permalink)
hghflyrjd1's Avatar
I have 2 12" Kicker CRVs with a 1500 watt amp.NO ISSUES HERE.$500 ticket to prove it...lol
Old 04-12-2011, 11:17 AM   #6 (permalink)
OK - I know diddly squat - enjoy your 1000 watter - 1500 watter - 350,000 watter - whatever
Old 04-12-2011, 11:20 AM   #7 (permalink)
hghflyrjd1's Avatar
Explain what you mean by he will fry so many batteries..thats all we asked.IF im up for a surprise then let me know.
Old 04-12-2011, 11:28 AM   #8 (permalink)
I've seen 100w systems installed in older 126 Merces-Benz cars eat batteries. Std. 60A-80A amp alt. replaced with 100A alt and problems with maintaining adequate battery charge continued.
Unplug the sound system amp and situation reversed.
Now I hear about something 10x greater in wattage. Has alternator output increased in relation to wattage by 10 fold?
I realize there have been technological advancements, but..........
So tell me.
Old 04-12-2011, 12:04 PM   #9 (permalink)
Ridin Slow...
Minus (-)'s Avatar
My Thing Is This Mike...What Your Saying Makes Sense....But Thats What The Remote Wire Is For...Its Not Continuous,Its Cuttin It Off n On....But I Guess U Do Kno A Lil Something...But Its Not Fryin....Also Update On The Sounds....I Got The Remote Goin Into The AC Lighter Fuse...Would That Work??....Well Its Working...But Will It Blow Or Malfunction?? Its a 15 amp fuse
Old 04-12-2011, 12:12 PM   #10 (permalink)
Minus(-):
What you are doing is interesting and admittedly I'm not up to speed on sound systems - just basic electrical matchup.
You say there's some cut out going on. Is a capacitor(maybe not the right terminology) employed in the circuit to keep a consistent flow of current during the phase-out/cut-off?
Voltage x amperage = wattage
Turn on the sound system; then fire up a Marlboro.
Old 04-12-2011, 02:08 PM   #11 (permalink)
hghflyrjd1's Avatar
The remote wire is used to turn the amp OFF when you turn off the car and on wen the car is turned on.So the amp does not draw power wen the car is off.Ive ad this in my car for the whole time ive owned it and no issues with the battery.
Old 04-12-2011, 02:11 PM   #12 (permalink)
Ridin Slow...
Minus (-)'s Avatar
And Your System Will BLOW My Shit Out The Water....So If Yours Is Still Up And Running...Mines Should Have No Problems...but Let Me Ask U...Where Do You HAve Your Remote Wire Hooked At??
Old 04-12-2011, 02:29 PM   #13 (permalink)
hghflyrjd1's Avatar
I admit I did not install this myself.Since i had the crazy 2way alarm remote start unit installed the same day i had a PRO do this.I would guess you need it connected to something that is ONLY ON when the ignition is powered on too.Also my Amp is a SUPER mono which means it draws less power.My buddy has the same subs but different amp in his 2007 charger and his lights dim when the beat hits.MINE DOES NOT.AND STILL HE HAS NO ISSUES with his battery.
Old 04-12-2011, 02:42 PM   #14 (permalink)
Ridin Slow...
Minus (-)'s Avatar
Ok....My Dude Will Figure It Out...Hes Not Worried Bout Battery Power...Im Just Using One..And Still Keeping Factory HU.....Still Researching.....Heres a Few Pics
Old 04-12-2011, 02:46 PM   #15 (permalink)
hghflyrjd1's Avatar
I also kept the factory HU.You'll be fine.I see you actually have a trunk after adding the box SHIT mine i can fit a small stroller and some bags thats about it.My amp is mounted first then the box so i can quick disconnect the wire and remove the box IN-CASE I NEED TO.The box and subs are just under 100 pounds.
