2007 Avalon wheel bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 05-25-2011, 09:35 PM   #1 (permalink)
View avalon35's Photo Gallery
Any idea if Avy's have wheel bearing issues? Also what are the symptoms if so? How to test?
avalon35 is offline   Reply With Quote
Old 05-25-2011, 10:12 PM   #2 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
Haven't heard of any issues since I've been hangin' around here. My '07 has 112,000 miles on it without issue.
Generally, a wheel bearing problem can manifest itself through a wobbling-noise, a vibration in the steering wheel or, when it's really bad, a squealing sound (as it shaves metal away).
2007 Avalon Limited - Love this car!
Tom in Tacoma is offline   Reply With Quote
Old 05-25-2011, 10:56 PM   #3 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
In my previous car I thought I had a wheel bearing issue. It was actually a cupped tire that made a sound similar to a bearing going bad (which I've also had in a previous previous car). Unless you have well over 100k I'd find it highly suspect that you would have a bad bearing.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 05-26-2011, 11:16 AM   #4 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
From my experience (not the Avalon but other cars) when you do 90 degree-turn and hear noise from the front,, that's the symptom.
grandpapa is offline   Reply With Quote
Old 05-26-2011, 11:41 AM   #5 (permalink)
'07 Avalon Limited
That could also be the constant velocity joint (CV-joint). That will make a crunching/knocking sound but only when doing a hard turn.
Old 05-26-2011, 08:53 PM   #6 (permalink)
I'm getting suspicious it is the tire (even though they only have 1200 miles on them) I can feel a constant super mild vibration in the steering wheel. My wife has a 2005 Subaru that had the back bearings go out in 5000 miles (supplier defective batch of parts), so anytime I feel a drag on any car I get overly sensitive.
-chad
Old 05-26-2011, 09:27 PM   #7 (permalink)
It Wasn't Me
-chad
Swap the tire with the full size spare on the side you hear the noise. If the noise goes away, you have your answer.
Old 05-26-2011, 09:40 PM   #8 (permalink)
If the tires aren't the same make do you think it will still be a good test.
Old 05-26-2011, 11:05 PM   #9 (permalink)
It Wasn't Me
You could also just swap front to back and see if the noise moves to the rear. You never really said if it was one side or front rear, etc.
Old 05-27-2011, 10:21 AM   #10 (permalink)
CISA93's Avatar
View CISA93's Photo Gallery
I had this problem, but in another car. It wasn't the CV joints or the front wheel bearings (they last well over 100,000 and can be checked for play with calipers removed. I removed the two front tires and I noticed something between the treads. Went into Discount Tire...tires were separating and they were replaced since they were under warranty.
CISA93 is offline   Reply With Quote
Old 06-20-2011, 03:48 PM   #11 (permalink)
View HiltonII's Photo Gallery
Do an advanced search under user name hiltonii, look at the wheel bearing thread. I had the same problem with my 07.
TSB #TSB-0106-08
NHTSA ID #10025856
  • <LI itxtNodeId="52" itxtHarvested="0">Date Announced: JUNE 11 2008
  • Additional Info: How to Fix
Summary: TOYOTA: FRONT SUSPENSION- SOME 2007-2008 MODEL YEAR AVALON, CAMRY, CAMRY HV, AND SOLARA VEHICLES MAY EXHIBIT A STEERING WHEEL FLUTTER AND/OR A BODY VIBRATION (FLOOR OR SEATS) AT HIGHWAY SPEEDS (APPROX. 65-75 MPH [105-121 KM/H]). *PE
HiltonII is offline   Reply With Quote
Old 06-21-2011, 02:22 PM   #12 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
M neighbors 06 Avalon needed a left rear wheel bearing replaced around 18,000 miles. It was squeeling. Dealer disagreed until it was removed and seizing was evident. Dealer replaced under warranty.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
