Trouble Code P0113 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 06-05-2011, 07:24 PM   #1 (permalink)
turbowanabe's Avatar
View turbowanabe's Photo Gallery
Trouble Code P0113
06 Avy, check engine light on, scanner says P0113, intake air temperature sensor 1 circuit high input.
Can anyone help? Any info is much appreciated.
06 Avalon Limited, Phantom Gray Pearl
03 Pontiac Vibe
1987 Buick Grand National
turbowanabe is offline   Reply With Quote
Old 06-06-2011, 12:10 AM   #2 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Check if the air filter is dirty, if so I will start by replacing it and clear the code. The intake air temp. sensor is built into the air flow meter(MAF) so check if the connection and wiring to the MAF is good. Make sure the MAF is clean too.
BTW the GN happens to be my favorite car.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 06-06-2011, 06:16 AM   #3 (permalink)
Thanks for the reply, and the great info! I'll check it out.
And thanks for the kudos on my GN!
03 Pontiac Vibe
Old 06-06-2011, 10:29 AM   #4 (permalink)
CISA93's Avatar
View CISA93's Photo Gallery
Before you clean the MAF, disconnect it, remove it and clean it with a MAF cleaner (for example CRC), the can should tell you how to perform this service. MAF sensors are not cheap, so lay it aside where it won't get damaged.
Also disconnect your battery and clean up under and around the lower part of your air filter housing, you'd be amazed how much garbage accumulates under there and around/inside those air intake hoses.
CISA93 is offline   Reply With Quote
Old 06-06-2011, 12:14 PM   #5 (permalink)
Thanks for the reply- more great info !
03 Pontiac Vibe
Old 06-10-2011, 12:10 PM   #6 (permalink)
Update:
Well, I cleaned underneath the battery box, installed a new air filter, and removed the MAF and cleaned it with some CRC Maf cleaner, reinstalled, and cleared the code-fired it back up and the code came right back!
Looks like it's time for a new MAF!
03 Pontiac Vibe
Old 06-10-2011, 10:14 PM   #7 (permalink)
CISA93's Avatar
Update:
I fried a MAF sensor once and ONLY once when I cleaned it while it was connected. You may need a handheld model to clear the code, some of these codes are not considered "soft codes" and need to be cleared not just by disconnecting the battery. The ECU stores the information.....as told by Nissan/Honda techs (since they all have OBD II systems) Just a thought before you go out and spend on a new MAF.
Old 06-11-2011, 07:30 AM   #8 (permalink)
I do have a hand-held scanner, and the code still comes back after clearing the code with it.
03 Pontiac Vibe
