You have two air mix control dampers; one for the driver's side and one for the passenger side that are independently controlled and operated by electric servo motors. It sounds like your a/c is operating fine since you get cold air on the passenger side. I'd suspect that the air mix damper on the driver's side is not functioning. The dealer has a tester for checking the function of all the different sensors, servos, etc. Before you do that, look under the dash on the driver's side, up to the right just under the water hoses on the side of the ventilation system. That is where the driver's side air mix servo is located. Look for wires and the connector that plug into the servo and make sure they are plugged in. They actually can get kicked loose. See if that fixes your problem. If not, then I'd leave it the dealer to replace the servo. Good luck!
2008 Avalon
1983 Toyota 4X4 pickup
2000 Dodge Ram 4X4
1979 Harley
