New Owner w/a question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 06-28-2011, 09:16 PM   #1 (permalink)
View Irish Legend's Photo Gallery
3rd Generation New Owner w/a question
I just bought an '05 Limited an want to know whats needed to fix a small problem. The center storage door won't close, the male part is broken off I guess. Where to get the parts, what I need and a how to is what I'm searching for.
Any help would be appreciated.
Thanks,
Brian
Irish Legend is offline   Reply With Quote
Old 06-28-2011, 10:07 PM   #2 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
are you referred to the armrest storage or the one below it?
I think the part number will be for the whole storage and you may have better luck searching on eBay or local junk (good luck on that)
grandpapa is offline   Reply With Quote
Old 06-28-2011, 10:34 PM   #3 (permalink)
The one below the armrest/console.
Old 06-29-2011, 06:49 PM   #4 (permalink)
I also noticed my seat memory isn't working, is there a fuse I should check? If so which one?
Thanks.
Old 06-29-2011, 09:10 PM   #5 (permalink)
Ridin Slow...
Minus (-)'s Avatar
Gameroom cash: $201800
View Minus (-)'s Photo Gallery
Check The Owners Manual
Avalonia Grey aka A.G.
JETS FOOOL!
Minus (-) is offline   Reply With Quote
Old 06-29-2011, 09:52 PM   #6 (permalink)
CISA93's Avatar
View CISA93's Photo Gallery
Call these online Toyota parts places and they'll give you a part number. IF you need someone knowledgable I have a point of contact in Phoenix, AZ. Those electric seats have electric relays, with electrical it's a process of elimination, start with fuses and cleaning the connectors or checking for good contact. IF you find a really (usually a large black box in the engine compartment. Look for a similar one (same number, wiring diagram on the relay) switch it out with another relay and see if it works.
Electrical problems are money makers for dealerships. One thing I had to do today was remove the alternator, the pulley clutch was going out (bearings feeling rough and a diode) It was less expensive to rebuild (reputable shop) than buy a new one (TOyota rebuilds there alternators. All of these cars use alot of electrical power and they go through batteries and alternators, so it's important to get an electrical check (and have a load check also) when changing your battery. Good luck!
CISA93 is offline   Reply With Quote
Old 06-30-2011, 10:43 AM   #7 (permalink)
Thanks.
not trying to be smart but it did take me a while to figure out how the memory seat work.
any beep when you press the buttons (set + 1/2)
Old 06-30-2011, 09:27 PM   #8 (permalink)
Thanks, both buttons at the same time did the trick.
Now to figure out how to keep the storage door from staying opened!
I'm a bit surprised by the power of the car too.
Old 06-30-2011, 09:34 PM   #9 (permalink)
View rmedina's Photo Gallery
I work at a toyota dealer as a sales person i will ask one of the tech and get back to you.
rmedina is offline   Reply With Quote
Old 06-30-2011, 09:36 PM   #10 (permalink)
on your memory seats reset may be the fix look at your manual read how to reset.
Old 07-04-2011, 08:08 PM   #11 (permalink)
Nothings better!
TheUltimateBohab's Avatar
View TheUltimateBohab's Photo Gallery
I was thinking the exact same thing I don’t have the memory seat option on my Avy but do on my Bimmer and it doesn’t work if you don’t know how to use it.
TheUltimateBohab is offline   Reply With Quote
Old 07-05-2011, 02:49 PM   #12 (permalink)
Memory seats are good to go.
Now for the storage lid. Any ideas?
Old 07-05-2011, 08:37 PM   #13 (permalink)
Nothings better!
The clip is snapped all the way off? If so I’m thinking that you may be able buy the lid/top for the compartment off eBay or somewhere I doubt you can just get the clip, but maybe.
