Originally Posted by LSU TUNDRA TIGER
I don't hear any noise at all from the motor. That's what led me to believe it was a fuse.
I believe the pump motor is located on the reservoir held by a rubber like ring. Check the connections, fuses. Clean out your windshield tank. I never use any blue window cleaner, I either use Prestone or Rain X, you can also buy a concentrate of Rain X, but recommended you use distilled water (no minerals and won't clog your spray heads by the wiper/hood area. never use Windex in the reservoir because it's tends to break down with the heat.
