Originally Posted by Minus (-)
I recently took a 12+ Hour Trip in my 08'.....During Braking At Highway Speeds My Steering Wheel And Car Shakes.....Took It To Toyota...They Said I Need Front Brakes And Rotors...I Still Have A lot Of Lining...But It Needs To Be Changed to Stop The Shaking...They Can Fix It For $550.....I Don't Really Care For Letting The Dealership Do My Work...What Kind Of Pads And Rotors Do Ya'll Suggest....And Where Can I Buy/Order Them From?? and What Do Mechanics Normally Charge For This....Thanx In Advance
Although I have an 09 Camry, it has the V6 engine and therefore suspension parts similar to an Avalon. I had the exact same problem as well as other issues. I was sure it was the rotors. Started a thread in the Camry forum entitled "
09 LE V6 - steering wheel vibration(s)/bad brake rotors-NEED HELP" as follows:
Turned out there is a TSB on the issue and the dealer fixed it at no charge and rotors had nothing to do with it as follows as it relates to your situation copied and pasted from the solutions noted in my thread:
1. Replace both brake pads and calipers on both front wheels as per TSB. Rotors were not warped and did not have to be turned. Parts as follows:
04465-33470 Pad Kit
08887-80609 Disk Brake Caliper
Cost: ZERO
Good luck and hope this helps.
