2006 Avalon Wiper Arm Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 08-24-2011, 07:42 PM   #1 (permalink)
View a31rod's Photo Gallery
Can someone give me a detailed decription of how to remove the wiper arms? I would like to access the area where the wiper arm equipment is...under the plastic vent grill at the base of the windshield. Does it just pull off by hand, or do I need special equipment (puller)? Thanks!
a31rod is offline   Reply With Quote
Old 08-24-2011, 07:49 PM   #2 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Pop of the nut cover, remove the nuts, make sure the arm is aligned with the tapered shaft and pull straight up.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
a31rod (08-24-2011)
Old 08-29-2011, 12:15 PM   #3 (permalink)
View Mike Murrell's Photo Gallery
Straight-forward as pointed out above.
You'll also need to do this(and remove grille) if you decide to change your own spark plugs(the 3 in the rear).
Mike Murrell is offline   Reply With Quote
The Following User Says Thank You to Mike Murrell For This Useful Post:
a31rod (08-29-2011)
Old 09-03-2011, 09:44 PM   #4 (permalink)
View tigerclaws1318's Photo Gallery
Pop off the cover and remove the 14mm nut holding it in place. Sometimes the arm is stuck on so you might need to rock it back and forth to get it off.
tigerclaws1318 is offline   Reply With Quote
The Following User Says Thank You to tigerclaws1318 For This Useful Post:
a31rod (09-04-2011)
