Radiator leak 2006 Avalon - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 08-30-2011, 02:03 PM   #1 (permalink)
View cincydave's Photo Gallery
Unhappy Radiator leak 2006 Avalon
Bought this car used about a year ago. Noticed some pink fluid on ground and car would intermitently overheat. Took it to the local dealer and said radiator is leaking and needs to be replaced. Car only has about 60,000 miles on it. Seems mightly early for something like this to happen. Anyone have similar radiator issues?
cincydave is offline   Reply With Quote
Old 08-31-2011, 07:59 PM   #2 (permalink)
View Mike Murrell's Photo Gallery
Mine has double your mileage and is holding up fine.
You did buy used - no telling what happened B4 you obtained the car?
I would say this.....if the radiator is leaking - I would not hesitate to repair/replace it.
If it springs a big leak unexpectedly - you could end up with a blown cylinder head gasket and on a modern vehicle - that can be bye-bye for the motor.
Mike Murrell is offline   Reply With Quote
Old 09-01-2011, 11:02 AM   #3 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
so what's the quote for the fix?
grandpapa is offline   Reply With Quote
Old 09-01-2011, 02:05 PM   #4 (permalink)
Nothings better!
TheUltimateBohab's Avatar
View TheUltimateBohab's Photo Gallery
Mine has over double the mileage of yours also and is still like factory great... I also bought used was yours wrecked at one point? Is it leaking right from a radiator? Or just a hose, if it’s a hose it probably won’t be too big a deal to fix.
TheUltimateBohab is offline   Reply With Quote
Old 09-01-2011, 04:10 PM   #5 (permalink)
The car was never in an accident. Got carfax before purchasing. I've owned it for about a year.Took it to the local dealer who said the radiator was leaking. Went ahead and bit the bullet and had it replaced. They actaully recomended aftermarket, which was cheaper and better according to them and had a lifetime warranty. He said the Toyota radiator only had a 1 yr warranty.
