Originally Posted by presbo
My wife drives our '08 the most. She says after we have put on new tires and had them mounted and balanced that she feels a vibration when she is stopping at 50 MPH at the end of the braking. Called the tire man and he said he would look at it. He also said it might be the brakes. Its the Original set of brakes. About 34,000 miles on them. My question is do you think I might need brakes?
well driving types do differ from one person to another, so brake life is dependent on how a person uses the brakes, rides the brakes, etc,etc.
now, given that, and that they are front brakes, the front brakes will wear out faster than the rear as all the weight gets shifted towards the front when we apply our brakes. the rear brakes come on, but all that weight transfer has no place to go, but up front.
ok, now.....if there was NO brake pedal before the new tires were put on then i would highly suspect the tire installer used the air impact wrench with all it's might/power, and probably over-torqued the lug nuts, warping the rotors....
you say...."when she is stopping"....this tells me, she has her foot on the brake pedal....
for added information, my dad's car had 55,000 miles on it before it needed front brakes..2000 Camry LE......
so if your wife is a "rider of the brake pedal" then yeah, she could be in need of a new set, as well as rotors now as well....always MAKE SURE ANY mechanic, tire changer, etc,etc, USES A TORQUE WRENCH TO PROPERLY TIGHTEN the lug nuts....!!!!
