Torque Spec request - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 10-15-2011, 06:13 AM   #1 (permalink)
ron in sc's Avatar
View ron in sc's Photo Gallery
Question Torque Spec request
What is torque spec for 2009 engine oil pan?
Bolt is 6mm with 1mm pitch threads and has 10mm head.
ron in sc is offline   Reply With Quote
Old 10-15-2011, 07:27 AM   #2 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
Oil Pan Sub Assembly: 15 ft/lbs except for the two at the rear of the pan right next to each other, those should be 7 ft/
Oil Pan Itself: 7ft/lbs
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 10-15-2011, 09:25 AM   #3 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
oil pan bolts are in FOOT pounds...and NOT inch pounds..????
Glenn8963 is offline   Reply With Quote
Old 10-15-2011, 09:38 AM   #4 (permalink)
ron in sc's Avatar
Originally Posted by boosted-fc3s View Post
15 ft/lbs except for the two at the rear of the pan right next to each other, those should be 7 ft/lbs
Where did you get you information? I ask because it seem like, at least me to be rather high values.
Usually a faster with the specs I quoted would be 5 or maybe 6 ft. lbs if it were a grade 8.8 bolt.
The value you gave would work out to about 180 in lbs. just seem to high.
If value is 5 or 6 ft lbs then inch pound value would be around 72 inch pounds which seem about right.
I just want to know for sure.
Old 10-15-2011, 03:40 PM   #5 (permalink)
It Wasn't Me
The factory service manual.
Old 10-15-2011, 07:18 PM   #6 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
LOOKS LIKE 7 ft lbs.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 10-15-2011, 07:22 PM   #7 (permalink)
Oh6War's Avatar
View Oh6War's Photo Gallery
I use the German torque. "Good n Tight"
Oh6War is offline   Reply With Quote
Old 10-15-2011, 07:57 PM   #8 (permalink)
It Wasn't Me
Whoops, if you look at your diagram, I was looking at the "sub assembly" hence the 7 and 15 figures. The FSM I have has only one diagram for the sub assembly only in the "oil pan" section. They dont even show sub assembly no.2 aka the actual oil pan. Crappy book I guess.
Old 10-15-2011, 08:38 PM   #9 (permalink)
View azgurney's Photo Gallery
Why did you have to remove the oil pan?
azgurney is offline   Reply With Quote
Old 10-16-2011, 11:29 AM   #10 (permalink)
ron in sc's Avatar
Thanks to all.
7 ft. lbs is about 84 Inch pounds and that sounds right for bolt this size.
Pan is being replaced because I hit road debris that dented it badly.
