Spark Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 11-14-2011, 01:30 PM   #1 (permalink)
View Black Knight's Photo Gallery
Spark Plugs
What are the OEM spark plugs for a 2006 Avalon?
I am going to replace them all since I have to replace the coil on #1 and have to pull the upper intake manifold to get to it. I read you don't have to pull the manifold and can use a flex socket etc... but it seems like the job would be easier pulling it, and it doesn't look too difficult to pull the mani anyway.
Black Knight is offline   Reply With Quote
Old 11-14-2011, 02:20 PM   #2 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $327000
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
Toyota Part# is a 90919-01247 or FK20HR11 which is the Denso number. Hope this answers your question.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is online now   Reply With Quote
The Following User Says Thank You to TOYOPARTSMAN For This Useful Post:
Black Knight (11-14-2011)
Old 11-14-2011, 02:21 PM   #3 (permalink)
By the way, I do sell to members here Genuine Toyota OEM parts for 30% off MSRP and I am an Authorized Toyota Dealer and a supporting Vendor here on the forum.
678-854-9601
Old 11-17-2011, 12:46 PM   #4 (permalink)
View Mike Murrell's Photo Gallery
The front 3 plugs are a snap.
The back 3 - whole 'nuther story.
To get the rears out - you'll also need to remove both wiper arms and the grille they go thru. This allows access to some nuts/bolts at the rear of the motor securing the air surge tank - Toyota's word for plenum.
The following covers the rest - provided by forum member inov8:
http://members.cox.net/n0v8or/Avalon...g%20access.pdf
Mike Murrell is offline   Reply With Quote
The Following User Says Thank You to Mike Murrell For This Useful Post:
brad_i2001 (11-25-2011)
Old 01-16-2012, 07:29 PM   #5 (permalink)
View mrv8's Photo Gallery
Does anybody have the linked info? The link is coming up dead.
thanks
Mrv8
mrv8 is offline   Reply With Quote
Old 01-17-2012, 08:07 PM   #6 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
If you contact me via the Private Message system (link at top right of this page), I will send you the referenced pdf file.
inov8 is offline   Reply With Quote
The Following User Says Thank You to inov8 For This Useful Post:
mrv8 (02-07-2012)
Old 02-09-2012, 03:09 PM   #7 (permalink)
Well, I got the coil replaced #1 cylinder and all the spark plugs. Even with the cowling stuff removed the rear plugs were a royal pita to access do to wire bundle in the way. I had a real hard time getting the passenger side plenum bracket bolt out, and even harder time getting it back in. Due to large hands and little patience, I used my cutoff air saw to make the bracket mount a slotted "U" shapped bolt hole. This made it possible to start the bolt, then put the plenum in place and tighten the bolt. I used MaxBlaster on the windshield wiper arms, and they popped right off. Also one of my hood support struts is bad so I have to use a stick to hold the hood open. I went ahead and removed the struts from the upper mount. This allowed easier access to the back of the engine compartment. Total cost for 1 coil, 6 ngk ir laser plugs, 3 gaskets, and a gearwrench set was less than $250. Quote from my mechanic withouth the plugs $400+ . I can't give a fair time estimate due to a lower back injury that would only let me work a few minutes at a time.
btw: '05 avalon 135k+ miles. Plugs were in perfect shape, still gapped same as new.
Old 02-17-2012, 03:08 PM   #8 (permalink)
that's good to know since I didn't replace mine yet, just the coil. I don't hqve 100K miles yet.
