Power steering fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 11-17-2011, 03:09 PM   #1 (permalink)
View gunmount53's Photo Gallery
USA Power steering fluid
I just had a 55K maintenance schedule performed on my 2008 Avalon and the service gal told me my power steering system needs a flush and refill. I think this is something I can do myself with a turkey baster but nowhere in the owners manual does Toyota indicate what fluid to use. Any help would be appreciated.
gunmount53 is offline   Reply With Quote
Old 11-17-2011, 04:37 PM   #2 (permalink)
View Mike Murrell's Photo Gallery
My '06 Abvalon came with traditional power steering fluid. I've used the Valvoline and NAPA brand. Valvoline makes NAPA lubricants.
Nothing special like you have with Honda's - they use proprietary power steering fluid.
Your transmission fluid is special - obtained from a Toyota dealer.
A tech on the Camry forum claims you can use Amsoil transmission fluid in lieu of the Toyota WS transmission fluid. I don't know if that's true.
Mike Murrell is offline   Reply With Quote
The Following User Says Thank You to Mike Murrell For This Useful Post:
gunmount53 (11-17-2011)
Old 11-17-2011, 05:27 PM   #3 (permalink)
I understand some auto brands use transmission fluid rather than a specific pwr steering fluid for their steering systems but Toyota is an exception I guess. Thanks for your help.
Old 11-17-2011, 06:04 PM   #4 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
I noticed the PS fluid was pretty black in the 07 last time I looked under the hood, the cap said the system used Dex II or Dex III ATF. The same fluid my 99 uses so I just changed the fluid while doing an oil change.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 11-17-2011, 06:07 PM   #5 (permalink)
Yes - my '06 Avalon and '04 Tacoma owners manuals say to use transmission fluid.
I find that very interesting as neither came from the factory with transmission fluid.
My '95 Isuzu Rodeo does actually use transmission fluid - came that way.
Pretty easy to distingush between the two.
Transmission fluid - regardless of what type is pretty much the same cranberry color.
Power steering fluid is an amber/golden type color - completely different.
Old 11-17-2011, 06:13 PM   #6 (permalink)
Avy
I can't remember where I read this, but the original power steering fluid is Dex III without the red dye.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 11-18-2011, 10:59 AM   #7 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
I too read this from HL, Camry and other toyota forums. It seems to point to
A) you either go to any part store for power steering fluid (if you want the clear one)
B) use the RED toyota transmission fluid since toyota doesn't carry "clear" "power steering" fluid. and they are the same, the RED just a dye
But the fact is the service manual never mentioned the fluid need to be change.
grandpapa is offline   Reply With Quote
Old 11-18-2011, 11:57 AM   #8 (permalink)
You would only change the power steeering fluid if you planned on keeping the car a length of time. My 2 cents.
Car mfgs. have toned down their published maint. requirements in a effort to reduce the perceived cost of ownership - marketing ploy.
They want you in a new car every 3-5 years. If that's your plan - you can simply keep air in the tires and ensure the fluids are at the correct level.
A service writer at a local shop told me of an experiment conducted by a shop with $$$ to burn.
They bought a Honda Accord - brand new.
Drove it 250,000. NEVER changed the oil - kept it topped up. Changed the oil filter once at 125,000 miles.
At 250,000 the car was still running. He never mentioned any other maint. done(or not done) to that Honda
True story - who knows?
Old 11-18-2011, 08:07 PM   #9 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
My dodge uses ATF+4 in the powersteering too. Its a 2002. My Avalon just hit 92k. I plan to keep it until 200k, so I'll probably be flushing all the fluids at 100k, trans, PS, coolant, brake, etc
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
