Whats involved in replacing brake pads on 2006 Avalon? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 01-06-2012, 08:19 AM   #1 (permalink)
Master Yoder's Avatar
View Master Yoder's Photo Gallery
I have a 2006 Avalon that needs new front and back pads. The dealer said there is 2mm of pad left when we took it in for a oil change. They wanted over $500 to replace them, LOL.
I found a reputable place that can do it for about $220 + tax with good pads or I can do it myself for about $90 plus turning the rotors if needed so that could add to the DIY cost but the brakes have not make any weird noise and no grinding. The dealer said they may beed to be turned but I don't see why.
My problem is time, so i am trying to determine if it's worth it to pay an extra $140 - $160 to have someone else do it and not have to worry about it.
About how long should it take to do the whole job front and back? Are there any goofy things to worry about with this model that could be a headache?
Master Yoder is online now   Reply With Quote
Old 01-06-2012, 10:25 AM   #2 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
Changing Brake Pads ( 1 2 3)
grandpapa is offline   Reply With Quote
Old 01-06-2012, 01:05 PM   #3 (permalink)
View Mike Murrell's Photo Gallery
If time is an issue and turning all 4 rotors is required - you might want to let a shop do the work. I only turn rotors if I'm experiencing shimmy applying brakes - an indication they're out of round.
When you pull rotors - you must also clean/repack wheel bearings(at least I would) and then you are going to have to set the preload on the wheel bearings. Get that wrong and one of 2 things happens:
- wheel comes off or wobbles badly - preload set too loose
- you burn up the wheel bearings - preload set too tight
Pad replacement is pretty much like most other Asian cars.
The URL below gives good insight into what's involved repacking wheel bearings and setting preload. Not for an Avalon - but principles apply.
http://www.planetisuzoo.com/articles...Bearing_Repack
Mike Murrell is offline   Reply With Quote
Old 01-06-2012, 03:25 PM   #4 (permalink)
Thanks for the info. If I were to turn the wheel and try to rub my finger across the rotor is it pretty easy to tell if it is gouged or are the grooves smaller than you can detect with a finger? I haven't had any weird noise or shaking so far. About 75k miles and I think they are original pads.
Old 01-07-2012, 03:11 AM   #5 (permalink)
05 Avalon Limited
rmike1991's Avatar
Gameroom cash: $108250
View rmike1991's Photo Gallery
Mike, I would disagree with this statement. It only needs to be done if the rotor and the hub is one piece. For example:
On Avalon you don't have to remove the hub, just the rotor and it looks like this:
Here is a diagram. You only have to remove #7(incl.#8) - caliper with mount and #5 - rotor.
#1
rmike1991 is offline   Reply With Quote
Old 01-07-2012, 09:01 AM   #6 (permalink)
It Wasn't Me
boosted-fc3s's Avatar
Gameroom cash: $370780
View boosted-fc3s's Photo Gallery
If your rotors are warped replace them. If warped rotors are turned, they WILL warp again, and much faster. Rotors are so cheap now it makes very little sense to turn them. I have 95k on my avalon and I still have stock rotors. They are well within spec yet.
2007 Avalon Limited w/ Laser Cruise 97K Miles and Counting...
2002 Dodge Ram 1500 Quad Cab 4x4
boosted-fc3s is offline   Reply With Quote
Old 01-07-2012, 12:03 PM   #7 (permalink)
I looked at the rotors with the tires on and felt them and they look and feel very smooth so I don't think there will be a need to turn/replace them.
Old 01-08-2012, 11:15 AM   #8 (permalink)
Mike1991 - thanks for the construction update on the Avalon - not one-piece.
The comment about rotors being so cheap these days is non-sense in my opinion.
I can have rotors turned for $10 each.
3rd part junk rotors are $40-$60 each - new OEM-from-A-Dealer rotors ordered online show up at $100 each! - That ain't cheap.
Old 01-08-2012, 04:54 PM   #9 (permalink)
It Wasn't Me
Dunno where you shop, but rear rotors can be had for $20 a pop and fronts for $30 from rockauto.com.
Old 01-08-2012, 09:21 PM   #10 (permalink)
I wouldn't entrust my life to a $20 rotor.
Rockauto's overall rating out of nearly 2700 reviews is 5.18 out of 10.
Not a company I'd want to do business with.
Old 01-08-2012, 10:59 PM   #11 (permalink)
It Wasn't Me
Eh, its all made in China anyways. All the local auto parts stores are all chinese crap too. Its more a matter of down time for me, I drive 25k miles a year, I cant afford to have my car out of service to keep getting warped rotors turned. I just prefer to buy new rotors if they are warped.
