Will a 2 Din fit in an '07 avalon? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 3rd Generation (2005-2012)
3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
Old 01-12-2012, 09:24 AM   #1 (permalink)
View bgseib's Photo Gallery
Was looking at replacing my factory radio with a gps/backup/dvd player and was wondering if anyone with aftermarket radios have been able to fit a 2 din or just a 1 din with kits?
Thanks,
Brian
bgseib is offline   Reply With Quote
Old 01-12-2012, 11:20 AM   #2 (permalink)
Offical TN Vendor
View AlfaOttoParts1's Photo Gallery
Take a picture of your radio, and I could let you know. Thanks
AlfaOttoParts1 is offline   Reply With Quote
Old 01-12-2012, 11:23 AM   #3 (permalink)
I have not picked out the new radio yet. I am not sure I need to be looking for a 1 or 2 din radio to replace stock. I was hoping a 2 din would fit so I could use the door panel still and not have to modify it to still be able to shut.
Old 01-12-2012, 01:07 PM   #4 (permalink)
pic.
Old 01-12-2012, 05:01 PM   #5 (permalink)
Gameroom cash: $142500
View 00avxls's Photo Gallery
I customized my radio trim to fit a double din
00avxls is offline   Reply With Quote
Old 01-12-2012, 07:06 PM   #6 (permalink)
Offical TN Vendor
IF your going to spend money on an aftermarket unit go with Dynavin's D99 Universal Multimedia GPS navigation radio.
It runs of ANDROID OS software
Old 01-12-2012, 07:07 PM   #7 (permalink)
Offical TN Vendor
you can download applications such as pandora, google maps, etc
Its the real android
Old 01-12-2012, 09:22 PM   #8 (permalink)
00avxls-that looks sweet! I don't know if my skills are that good at modifying trim pieces. What unit did you put in there?
The d99 looks pretty sweet too - prob too high a price tag for me.
Old 01-13-2012, 07:06 AM   #9 (permalink)
That was the first time I've ever done anything like that. Thought I'd give it a shot. I don't remember the model number of the kenwood radio I have but I bought it because I had a kenwood single din flip up screen at first and wanted to keep my add on navigation and siriuis.
Old 01-13-2012, 01:40 PM   #10 (permalink)
Offical TN Vendor
The D99 is on sale for forum users for $665. This includes back up camera. You will need to buy correct harness (I can point you in the direction).
Old 01-13-2012, 01:41 PM   #11 (permalink)
Offical TN Vendor
From the look of the radio, it seems as if you pull out the unit the universal unit should fit. Did you buy a frame? or any other trim pieces?
Old 02-20-2012, 03:18 PM   #12 (permalink)
Gameroom cash: $241400
View kingo's Photo Gallery
The problem with aftermarket radios and avalon isnt the space. There's a lot of realestate behind the panel and with a little bit of customizing you can give it a factory look and install almost any aftermarket.
The real problem is the factory radio's wiring that also controls the air conditioning. If you remove the factory radio, A/C doesnt work and if not mistaken also the blue screen wont either. I think someone posted a how to using a custom made or altered harness to connect and leave the original radio in the trunk while using an aftermarket.
kingo is offline   Reply With Quote
Old 02-26-2012, 08:05 AM   #13 (permalink)
View AVA1's Photo Gallery
I'm looking to do the same there is another member here and this is what he did and I quote:
"E17 pin 9 & 10 are the wires that I cut from the harness leading into the dash away from the radio and installed the 68 ohm resistor across to keep the display/climate control working"
What I will do is unpin the wire from the plug instead of cutting, once the two wires are removed from the plug I will bridge them using a 68 ohm resistor, this way it is reversible if needed.
AVA1 is offline   Reply With Quote
The Following User Says Thank You to AVA1 For This Useful Post:
kingo (04-30-2012)
