Only one way to tell if the rotors are warped. Pull them and bring them to a shop that turns them. Ask them to do a surface check and spec. them to see if they are still within tolerance limits.
This will isolate whether or not the rotors are warped.
Taking it in for an inspection, they will just look at pad wear and if you complain of shudder they will test drive and confirm and most likely jump to the conclusion that you need pads turned. Then they will insist on using new pads. If Minus is right and it is not pad/rotor related, you will have new pads and rotors sooner than you really needed.
it is fast and easy to pull these rotors. Both sides can be done within 45mins. you'll just need a ride down to the shop. Good luck and let us know what you find.
Joey
2010 - Avalon Limited - Black - "Night Hawk"
"Hey buddy, does your car have a laser?"
