TSB EG029-07 and EG033-07 - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
post #1 of 2 Old 06-30-2008, 05:35 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hey guys I've going to set up an appointment w/ the dealer for routine maintaince to be done on my '06 Avalon XLS, and I hope to have the ECM reflashed and the (somewhat) infamous poping noise problem from the steering wheel fixed.
Now I just did my homework for the TSB's relating to the ECM reflash, and I found two TSB#s: TSB EG029-07 and EG033-07. So are both TSB#s apply to the same problem? If not, which one is applicable for my Avalon?
Also, I found TSB ST002-06 which addresses the steering wheel poping noise issue. Can someone confirm this as well? BTW, what other TSB out there that can be performed on my Avy?
I'm trying to equip myself with the info I need so (hopefully) I won't get jerk around by the dealer. So if you're in the know, please share the knowledge
Gee Spoolin is offline
post #2 of 2 Old 07-01-2008, 07:51 AM
Avalon Enthusiast
Quoted: 28 Post(s)
This is a summary. If you would like a copy of the actual TSB, use the Private Message system (left column on this page) to contact me. I also have the TSB for the revised steering column design to eliminate the "popping" noise heard/felt while turning at low speeds (and sometimes on stop/start of the vehicle).
Technical Service Bulletin EG029-07 June 6, 2007
ECM CALIBRATION: ENHANCEMENT TO SHIFTING PERFORMANCE & SMOOTHNESS
’06 -- ’07 Avalon
PURPOSE:
To enhance shifting performance and smoothness during acceleration, the Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM) calibration has been revised. Please use the following procedure to address customer concerns.
NOTE:
Before proceeding, verify the ECM (PCM) calibration has NOT been updated by checking for the Authorized Modifications Label (shown in step 1 of the Repair Procedure).
APPLICABILITY:
2006 -- 2007 model year Avalon vehicles produced BEFORE the Production Change
Effective VIN shown below.
MODEL PRODUCTION CHANGE EFFECTIVE VIN
Avalon 4T1BK36B#7U243331
MODELYEAR . . . PREVIOUS P/N . . . CURRENT P/N . . . PART NAME . . . QTY
2006 . . . . . . . . . 89661—07450/51 . . . 89661--07471* ECM ( PCM) . . . . 1
2007 . . . . . . . . . . 89661—07470 . . . . . 00451—00001 . . . .Label**. . . . . . . . 1
** Authorized Modifications Label 1
* The ECM (PCM) should NOT be replaced as part of the Repair Procedure.
NOTE:
Authorized Modification Labels may be ordered in packages of 25 from the Materials
Distribution Center (MDC) through Dealer Daily Dealer Support Materials System or by
calling the MDC at 1--800--622--2033.
OP CODE DESCRIPTION TIME OFP T1 T2
EG7023 Recalibrate ECM (PCM) 0.9 89661--##### 26 99
APPLICABLE WARRANTY*:
This repair is covered under the Toyota Federal Emission Warranty. This warranty is
in effect for 96 months or 80,000 miles, whichever occurs first, from the vehicle’s
in-service date.
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
inov8 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 3rd Generation (2005-2012)
User Tag List
Linear Mode Linear Mode
Back
