Rear window sunshade buzzing - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
post #1 of 20 Old 07-18-2010, 02:53 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 2005 Avalon Limited. A couple of weeks ago I put the car in reverse and I started hearing this loud buzzing noise coming from the rear window area. I narrow it down to the rear window sunshade. It also makes this noise when pressing the button to lower the shade and maybe sometimes risening it. I know it has something to do with the relay or motor when the signal is sent to it to lower it, because a lower the shade signal is sent when the car is put into reverse or button is pushed. Does anyone have any suggestions on how to find the motor or relay without taking the rear seat out. Right now I would rather just disconnect it to stop the annoying buzzing noise. Where can I find a service/maintence manual to maybe find out how to disconnect it.
Thanks
Dave
Barcodeguy is offline
post #2 of 20 Old 07-18-2010, 04:58 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Temp solution
I removed the 10A fuse for the RR sunshade. That did the trick for now until I can find the relay and motor. There is no easy access to the sunshade.
post #3 of 20 Old 08-21-2010, 07:50 AM
Quoted: 0 Post(s)
same problem
Haha - the internet is amazing!
I am having the same exact problem.
The buzzing just started yesterday.
Prior to yesterday, the motor (I assume) has gotten weak and sometimes the shade will not go down at all.
I was going to try and disconnect the motor as well, but thanks for the tip on just pulling the fuse. I am headed outside right now to pull it.
After that I will begin searching for anyone experiencing another problem, when changing the position on the driver seat (pre-programmed) between setting 1 and setting 2, it makes a loud noise, like something needs to be greased.
05-avalon-lmtd is offline
post #4 of 20 Old 08-21-2010, 05:10 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Fuse Location
The top of the fuse box cover should have the fuse listed as RR S/SHADE. The fuse is located in the the center of the fuse box between SPARE and WIP.
The Following User Says Thank You to Barcodeguy For This Useful Post:
Ricko (05-29-2017)
post #5 of 20 Old 05-12-2011, 05:28 PM
Quoted: 0 Post(s)
Thanks
Dave
I have the same problem on an '05 Avalon I just bought. The previous owner just told me it stopped working and Toyota said it would cost about $300 to fix. When I got the car home and checked around, I found the fuse had been removed. This was obviously done to prevent the annoying buzzing sound that happens every time it is activated. It sounds to me like the motor is working fine but the gears that it drive are not meshing correctly therefore it sounds like a buzz. Mine shuts itself off after several minutes of operation, how about yours? Has anyone posted a fix or repair procedure for this yet?
utahtoyotaman is offline
post #6 of 20 Old 05-12-2011, 06:08 PM
Quoted: 0 Post(s)
Temp Fix Also
I got mine to go down by activating it from the button and then quickly getting in the back seat and pushing gently inward on the two up-right arms until it fully retracted. It was still buzzing even in the fully downward position. I pulled the fuse to de-avtivate and I'm going to get the windows tinted. DONE!
post #7 of 20 Old 05-16-2011, 09:19 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
No replies on a fix or even how to get motor to try to fix it. I ssume the back seat needs to come out to get to it.
utahtoyotaman (05-16-2011)
post #8 of 20 Old 06-06-2012, 10:01 PM
Quoted: 0 Post(s)
like most of you, i ended up disconnecting the fuse.
740ilsamuel is offline
post #9 of 20 Old 12-21-2013, 06:12 PM
Quoted: 0 Post(s)
Avalon Rear Power Shade
Hello Guys,
First, thank you all for posting your comments. I'm a newbie here. I have a 2008 Avalon Ltd with barely 55,000 miles on it. I live in sunny North Carolina so the thought of the rear shade vs tinted windows was a no brainer. WRONG!! The shade stopped working in the up position recently and the dealer here was like 'this doesn't happen". My reaction was "face it Fred, it's happened. Now what do we do?
After 30 minutes, my car is brought to me shade down, I'm a happy camper, since I did not buy with the navi system and handy backup cam. 2 days later I start the car to exit the drive way and the shade pops up and continues working for 2 weeks. Now we are at the beginning, stuck in the up position. (Does BMW have this problem?)
Here's the kicker. getting the car inspected and i'm told the 3rd stoplight is blown..but to get to it the shade is in the way I insist on leaving the shade in place. When I got my bill .. And of course a salesman catches me waiting for return of my vehicle and asks politely, " would you care to look at the new Avalon...facial expression ( can't print here)!!!
Avyluvr is offline
post #10 of 20 Old 12-26-2013, 10:56 PM
05 Avalon Limited
rmike1991's Avatar
Quoted: 5 Post(s)
No it's not. Just fixed mine not too long ago.
rmike1991 is offline
post #11 of 20 Old 11-22-2014, 01:37 PM
Quoted: 0 Post(s)
I have a 2006 Avalon Touring. Same problem. Had to take out back seat's Seat Back; 2 side panels, seat belts & rear window lid to gain access to rear window shade unit. It came out easily. I started taking apart drive motor & found Plastic gear with broken teeth.
Being as this is a specialty gear, I found Al Meekins on the Internet who made me a New Brass gear for $175 vs. $1,000 bill to pay to have Toyota replace the whole Rear Window Shade Unit. I know the price because they replaced it once before about 2 years ago.
If you want to contact Al Meekins, email him at ameek3775@aol.com but first call him at (856) 858-6421. He is a Top Notch individual and I give him the highest rating possible.
MrPhoto1199 is offline
post #12 of 20 Old 12-30-2014, 12:53 AM
Quoted: 1 Post(s)
most likely not broken
i spent a day taking apart my car to take out the rear sunshade to see if I could fix it!! It's quiet a bit of work!! Before it would go up but needed help going down, made a buzzing noise!! Anyways I took out the sunshade and took apart the gear case!! Spring came flying out and the gears. If you take it apart slow that won't happen!! Anyways I looked at it and nothing was wrong I put it back together and it works no problems!! all the gears are metal so it would be very unlikely that it is broke most likely out of place do to accident or something getting caught!! Take the gear that is the smallest out and the mental rode it is on out and put it back and that should fix it!! It seems to me the metal rode gets out of place just a little and that is what causes the sound and problem!! Your welcome !! This part to have Toyota fix is about $1500
Matthew Goff is offline
post #13 of 20 Old 06-07-2015, 11:17 AM
Quoted: 0 Post(s)
Our 2005 Limited does not have a RR Shade fuse. (Or a Spare or WIP for that matter). Would definitely like to pull the sun shade fuse but can't locate same. Any ideas please? Thanks
BillKP71 is offline
post #14 of 20 Old 06-08-2015, 07:08 PM
Avalon Enthusiast
Quoted: 29 Post(s)
On my '05, the fuse is located in the panel just above the parking brake pedal.
inov8 is offline
The Following 2 Users Say Thank You to inov8 For This Useful Post:
BillKP71 (06-15-2015), Ricko (05-29-2017)
post #15 of 20 Old 06-15-2015, 02:31 PM
Quoted: 0 Post(s)
Thanks! I was only looking at the fuses in the engine compartment.
BillKP71 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 3rd Generation (2005-2012)
User Tag List
Linear Mode Linear Mode
Back
