Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Re: Cigarette lighter doesn't work on a '97 SR-5 4-Runner
View Single Post
Old 12-22-2006, 12:03 AM   #6 (permalink)
Gordon
Guest
Posts: n/a
View Gordon's Photo Gallery
On Thu, 21 Dec 2006 14:10:32 -0800, "Jeff Strickland"
<crwlr@yahoo.com> wrote:
[color=blue]
>"Gordon" <gjewusa@netscape.net> wrote in message
>news:lerlo25f8q9e8drded99u7tpt3jhe18hmj@4ax.com...[color=green]
>> On Thu, 21 Dec 2006 06:42:07 -0600, "Noon-Air" <Noon-Air@comcast.net>
>> wrote:
>>[color=darkred]
>>>THey might *look* good, but did you actually pull them out and test them
>>>with a multimeter??
>>>Seems to me that the owners manual should tell you what fuses go where and
>>>to what accessory.
>>>news:h95ko2h473j7fv22e8ef69558f16taqjui@4ax.com...
>>>> On Wed, 20 Dec 2006 19:47:17 -0600, "Noon-Air" <Noon-Air@comcast.net>
>>>> wrote:
>>>>>ummm.....is there a fuse box under the hood nest to the battery box??
>>>>>news:obpjo2162vdhulhc8o2j9dv0p5qlhd23c3@4ax.com...
>>>>>> After using a portable air pump to air up my tires the cigarette
>>>>>> lighter doesn't work anymore. I've check the fuse box near the drivers
>>>>>> door and all the fuses look OK. Everything else works just fine.
>>>>>> Is there a fusible link for the cigarette lighter or another fuse box
>>>>>> that I can check?
>>>>>> Thanks for any help.
>>>> Yeah I looked at that one. The fuses look OK also. Those under hood
>>>> fuses seem to be for the engine and other things.
>>>[/color]
>> I'll give it a shot and test the buggers.[/color]
>Gordon,
>The fuses for circuits that are inside the cabin -- the cig lighter, radio,
>turn signals, for example -- are located behind a cover on the left end of
>the dashboard, if my memory serves me.
>[/color]
I found that fuse box and changed out the accessory fuse. But the
lighter still doesn't work. I didn't see a fuse for only the lighter.
The others were labeled: ign, gauge, wipers and ecu.
