Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Amp Install Problem
View Single Post
Old 12-31-2006, 12:44 PM   #3 (permalink)
160swiftly
160swiftly's Avatar
View 160swiftly's Photo Gallery
Originally Posted by wireless
The remote wire is simply a 'swtich' so the ignition triggers the amp to power up and it doesn't stay on all the time. Any switched source in the fuse box will work. How about the radio fuse? Tap into the circuit downlink from the source (the side of the fuse that has the wire going out to the radio).
BTW: On the wiring harness for your head unit, the ignition wire is usually yellow.
Thanks, problem solved. I used a piggyback fuse link.
160swiftly is offline   Reply With Quote
