Originally Posted by wireless
Only if your H/U can match the output of the JBL amp. If your H/U is underpowered for the speakers they will blow. Lack of power will blow a speaker quicker than too much power (assuming the distortion levels are the same).
not because of lack of power, distortion is the only reason them speakers will blow from his headunit. and the only way he is going to get enough distortion to blow them speakers is if he is blasting his music beyon the capabilities of his h/u. as long as he doesn't do that and recognizes the volume level where distortion enters the system and dont turn the volume past that point, those speakers and that built in amp inside the h/u will be fine. lack of power doesn't blow speakers, distortion kills speakers. that's why you can kill a speaker no matter if its overpowered, underpowered, or power to specs, because of distortion.
