Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Drum to disc-2003 Camry
View Single Post
Old 01-01-2007, 12:02 PM   #8 (permalink)
touringcamry
touringcamry's Avatar
Gameroom cash: $550825
Kocho did a drum to disc conversion on his Gen 4 Camry and has posted a DIY in the past. Gen 4 and Gen 5 are somewhat different, but you may find the DIY useful.
Originally Posted by batorok
any suggestions then on how to improve my braking performance? the difference between the se/xle and le is measureable in feet. I have abs, I upgraded to 28 inch alloys with falken 512 speed rated tires (helped handling a lot but not braking). Do performance pads help? Should I upgrade the FRONTs to the se/xle setup instead, which should be less difficult?
thanks
How did you fit 28" wheels on your car? That rim alone is larger than the overall diameter of the original wheel.
2007 Camry 2.4L 5M
