Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - New Rims/ TPMS sensors?
View Single Post
Old 01-03-2007, 07:53 AM   #13 (permalink)
Klutch
View Klutch's Photo Gallery
Originally Posted by BigWillie
If you read the owner's manual, there is a procedure to reset the system after tire service. I've have done it myself with no problems.....although I will add that my light always comes on now when the outside temp drops below 32 degrees F. I had my tires rotated at Town Fair Tire in NH, they said they can reset the TPMS for $20 and said the dealer would do it for a lot more, but then told me that the owner's man tells you how to do it. So naturally, I did it myself.
Now I have a cold weather issue and the dealer says the light will come on because of the pressure drop with the cold weather, but if its always around freezing temp, wouldn't that make the TPMS system useless and defective? Even after driving 30 miles the light still stayed on. I think the TPMS is BS anyway, what good is it gonna do when you have a blowout at 70 mph!?!? I always do a walk around my car every so often, can't help it I detailed cars for many years and am paranoid about anything being wrong!
The Automotive/Tire industries had better work out any issues with the TPMS or there might be some opposition, but from what I've researched, the US Gov is the driving force behind this system and DON'T you dare oppose the MAN!!
Interesting, my light hasn't been coming on with the weather changes. Sounds like you might be getting a bunch of smoke blown up your booty.
I read in either the owners manual or the service manual that if you rotate the tires the computer needs to be hooked up and the ID tags written down as they pertain to the tire location and once rotated they needed to be adjusted accordingly.
Klutch is offline   Reply With Quote
