When you reset it, as th emanual says. all you are doing is reseting the threshold pressure. The sensors will detect the difference in pressure, not the actual pressure at a given time, for example if you reset your set and your pressure was a 32 the light will come on once the pressure drops to 6lb (??) under the set value of 32psi. .If you reset it at 25 psi then the light will come up once the pressure drop 6lb under 25!. Read the manual. The sensor doesn't know the actual pressure on tire, it will only "see" the difference in pressure.
If you change your sensors you need to input the sensors ID in the Toyota ECM, to do that you need to have a Toyota programmer for the ECM (cost a lot of cheeseburgers). There are other vehicles that you just reset it and thats it, NOT with the Camry you need the ID in the ECM to have communication.
2007 Camry SE V6 /Leather/sunroof/JBL
Added: XM Sat Radio (Toyota), 18in Wheels (Rial), 3M Tints (35%), LED Interior lights. TRD Lowering Springs
Removed: Camry Se Badges
