Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Lower the compression
View Single Post
Old 01-04-2007, 04:43 PM   #6 (permalink)
Luckynumber5
engineer in training
Gameroom cash: $145055
Well, Ive seen 5sfe turbo builds make over 220whp on a stock engine (low mileage) but the powerband sucks, you can really see how the stock cams let the enigne down past 4k rpm.
What I would do is turbo the stock engine and keep it conservative so nothing breaks, then start building up a spare engine like I said and then get some cams for it, forged 8:1 pistons and rods + headwork + cams + Megasquirt is not an expensive build and you can get more power out of it than you will be able to put to the ground.
Traction will be a major problem, if you have the money consider going with a built automatic from importperformancetrans.com (IPT) they can set you up with a lsd and a reliable transmission and you will be able to give awd cars a damn good race, but its very expensive, more than the engine will cost to build. Plus on the auto is once its built, youll never have to worry about a cluch going out or crunching a gear.
Thats only if you are really looking at like 400+ ho out of the car. Its very doable but remember, its still a wrong wheel drive Celica
