Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - tapping noise in engine
View Single Post
Old 01-05-2007, 03:56 AM   #4 (permalink)
Unco
Unco's Avatar
View Unco's Photo Gallery
yes, it did make a similar noise, like a tapping and it kept getting worse. once i managed to snap the end of the driveshaft altogether because of a bad hub bearing.
if it does turn out to be the hub bearing, check out the hub itself, where the bearing sits as it could also be worn out. if that's the case, just get a good one from the wreckers, they're fairly cheap.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
