Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2000 Camry power window not working
View Single Post
Old 01-05-2007, 08:18 AM   #6 (permalink)
DFBonnett
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
I'd pull the door panel and check the window for binding. If it's not that, then the internal magnetic reed switch that kills the power to the motor when it stops moving has failed. You could try to pull the motor apart and clean it. I've yet to do that successfully, but you may have better luck.
FWIW
YMMV
DFBonnett is offline   Reply With Quote
