Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Override for Navi - v5.1 LOADING.KWI File
View Single Post
Old 01-08-2007, 01:57 PM   #9 (permalink)
pillpusher84
2011 BMW 535xi M-Sport
pillpusher84's Avatar
View pillpusher84's Photo Gallery
Gen6
Originally Posted by smilepak
What software are you using to re-author it?
Do you first extract the 6.1 disc to a local folder on the HD, replace the load file, and use something like NERO to burn a new disc?
To to the inital extract of the 6.1 disc, do you just copy from DVD to HD or a software have to extract it?
1. Copy all file from v6.1 dic to a folder on your Hard Drive
2. Replace the LOADING.KWI in the folder on your hard drive w/ the one I've provided!
3. Use Nero (or your favorite software) to create a DATA DVD (Dual Layer of Course)
4. Add all the files from your folder to the DVD & BURN IT.
5. Remove your old NAV DVD & replace it w/ the freshly burned DVD into your NAVI (in car).
6. Do the volume screen override
Press Menu
(menu screen appears)
Press Volume
(volume screen appears)
Press upper left corner
Press lower left corner
(Service Menu will appear)
Press and hold Over Ride for a few seconds
NOTE: If you are unable to get the SERVICE MENU up w/ the above procedure, this means you are still running v06.1 firmware ... please disconnect your NEGATIVE BATTERY TERMINAL & let the car sit for about 5 minutes ... then reconnect. This will clear out the NAVI's memory & when it comes back on, it will have to reload the firmware from your newly burned DVD, then the procedure should work!!
Current Rides:
2011 BMW 535i M-Sport xDrive (Mine), 2010 Infiniti G37S Convertible (Wife's), 2010 Toyota Rav4 Base 4cyl (Dog-mobile)
Previous Rides:
2010 Lexus RX350 AWD, 2007 Lexus GS350 AWD, 2007 Camry XLE V6, 2005 Acura TL, 2003 Nissan Maima SE, 1998 Lexus ES300
pillpusher84 is offline   Reply With Quote
