Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Car Is a turd
Thread: Car Is a turd
View Single Post
Old 01-11-2007, 06:03 PM   #10 (permalink)
marc780
View marc780's Photo Gallery
I'd do a compression check and/or an engine leak down test. Also a vacuum reading is simple and could help tell you if the cat is clogged.
these tests will give you a good basis to start with on this engine and if you get low compression readings you wont waste your time changing sensors and so on -
