01-12-2007, 09:31 PM
#11 (permalink)
Originally Posted by REN69
bring on the pr0n!
you asked for it!
- 1.8 litre 7a-fe block oversized, decked and machined
- 7a-fe crank with new oem bearings
- 7a-fe rods with new oem bearings
- 4a-gze US Spec 8:1 pistons 81.5mm oversized new OEM
- Estimated 8.8:1 compression
- New oem piston rings
- New oem head gasket
- 4a-ge big-port head, ported, decked et machined
- 3s-gte intake and exhaust valves
- HKS 264 intake and 256 exhaust cams 8.35mm lift
- homemade adjustable cam gears
- New oem water pump
- Shimmed new oem oil pump
- TRD thermostat
- 4a-ge big port NA intake and throttle body
- Complete oem gasket and seal kit
- Toyota Previa Van 2tz-fze SC14 1435cc supercharger with 125mm SC12 pulley
- Blitz Dual Drive Blow-off valve
- 7m-gte front mount Intercooler
- 7m-gte 440cc injectors
- Venom High Flow 3s-gte fuel pump
- AE101 gze turbo pressure sensor OEM
- AE101 gze ECU
- AE101 Crank sensor
- AE101 gze coils packs
- 7m-gte igniter
- E-manage piggyback unit with injector harness and Greddy map sensor 3 Bar
- Custom coolant piping
- Custom intercooler piping
- Custom wiring
- Custom engine mounts and accesory brackets
- New oem belts
- HKS Crank pulley with dampener
- K&N air filter
- Twincore OEM Toyota radiator made to fit
- Trimline Flexalite electric fan with home made relay
- ACT clutch kit (pressure plate, clutch) good for 300 lbs of torque
- 2.5" exhaust piping
- Hi-Flow Dynomax catalyst
- Hi Flow Dynomax 3 pass exhaust
