Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 3sge rear main seal?
View Single Post
Old 01-14-2007, 02:20 PM   #9 (permalink)
alltracman78
Alltrack Wannabe
View alltracman78's Photo Gallery
Originally Posted by conechaser
As I am an ASE master tech with 25yrs experience I think I know how to properly install oil seals.
My apologies.
I don't usually see someone like you asking that type of question.
If they do, they normally state they have the experience so [hopefully] dumb stuff can be ruled out....
No worries.
I do have 1 question.
You said it's the "dust seal portion".
Yet it seems to be the part that seals the crankshaft "shaft" that you are talking about.
The part of the seal that the inner spring holds to the crank.
Toyomoho has a good suggestion.
Some random suggestions.
Is the spring too tight?
How easily does it slide onto the crank?
I have to ask, theres no damage on the crank itself, right?
Your problem might be hardened NOS.
Also, Toyota warrenties thier parts.
Usually only if installed at the dealer, but they might warrenty it for you. :shrug:
It won't hurt to try.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
