Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - brake light indicator stays on
View Single Post
Old 01-15-2007, 03:24 AM   #9 (permalink)
bonnie*
bonnie*'s Avatar
View bonnie*'s Photo Gallery
make sure your brake lights and parking brake works OK.
make sure brake fluid level is not dropping over a day or two. IF IT DROPS DOWN THERE IS EXTERNAL LEAK IN BRAKING SYSTEM.
If above things are OK, fluid is not dropping in level, then target following components in following sequence.
DO YA FEEL DIFFERENCE IN BRAKING AFTER BRAKE LIGHT STAYS ON, DO YA HAVE TO PUSH BRAKE PADLE MORE DOWN TO THE BACK-(FIRE)-WALL???
IF YOU TELL US HOW YOU BRING A CAR TO A COMPLETE STOP, PROBABLY WE CAN HELP YOU OUT.
1) AIR ENTRAPMENT : BLEED THE SYSTEM PROPERLY AND RE-TOP THE BRAKE FLUID. ALSO MAKE SURE ROTOR & PADS , and DRUM & SHOES are within minimum specification.
1) MASTER CYLINDER : internal leak in master cylinder fails to hold and sustain INTERNAL PRESSURE.
2) BRAKE POWER BOOSTER (RARE CHANCES)
3) BRAKE PROPOSITION VALVE (RARE CHANCES)
bonnie*
ALWAYS TRY TO SOLVE RATHER THAN CREATE A NEW ONE!!!
bonnie* is offline   Reply With Quote
