Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - help! just did a headgasket..
View Single Post
Old 01-15-2007, 03:55 PM   #12 (permalink)
diver9000
diver9000's Avatar
View diver9000's Photo Gallery
Originally Posted by 89corolla4wd
i found the problem. i installed the half of the housing the distributor slides into backwards so it doesnt seal.. i feel like an idiot . The car still smokes.. i did a compression test and it was 180,180,165,190. doesnt look that bad.. could you have a leaking gasket and still have 165 psi compression?. any other ways water can get into the engine and get burned.. like coolant leaking into the throttle body or something? any input appreciated.
Water can get in if you have a cracked block. If you didnt seal the headgasket or it ripped while replacing it could cause a leak. Your question is a bit unclear. You mention the engine is smoking and the dizzy isnt installed properly, and then you jump from that to water being burned or some kind of coolant. What is the actual problem that you seem to be having now?
diver9000 is offline   Reply With Quote
